Maybe I can crawl under and jam a screwdriver in there. Strange there's no mention of it in all the vids I watched with the exception of yours but hes not clear on the removal process.
Stranded until then with it.
OK I just went out to the garage and in a box on my PSD shelf it so happens that I kept my old tensioner, it looks like you just cut the clip with side cutters. I would try and hold the tension while you cut it so it doesn't fly open violently (it will actually slam shut at the clip end) or just twist it out then cut off the excess.
Thank you for your kind replies! All that is needed apparently for future tensioner novices is a bit of *** into the breaker bar and the thingy will release!
