Removing Door Panel
Old Feb 7, 2024 | 08:28 PM
Omni43's Avatar
Omni43
Removing Door Panel
I have a 72 F250 2wd; and I need to remove my door locks and work on them, appears they are seized up and won't function. I can't find info about removing the inner door panel to get inside the door itself. If someone can direct me to a video or a step by step that would be very helpful.
Thanks.
Old Feb 7, 2024 | 09:59 PM
RichS2659's Avatar
RichS2659
Which trim level do you have? The Custom panels have screws which are screwed into plastic inserts IIRC. To get those out, you might have to pry up slightly with something gently on the panel as you are turning the screw. For the vinyl Sport Custom + panels, they are held in with clips which you have to gently pry up.
Old Feb 7, 2024 | 10:11 PM
FoPar1972's Avatar
FoPar1972
I can only assume you have the trim ring that covers the screws. Pictures of your door would be helpful as there were different interior options. The video attached shows a 1969 but if you have the trim it all comes off the same. I would not use a screw driver like he does I would use plastic trim tools (see screen shot I pasted below of said tools) so you don't scratch up the door or the panels. Also if you use trim tools they shouldn't "bust" as he says. Just my 2 cents anyway.
Hope this helps, good luck
Old Feb 8, 2024 | 01:00 AM
Green72F250's Avatar
Green72F250
There's a lot of good information on taking apart doors here:
How to Completely Disassemble a Door - FORDification.com
Old Feb 8, 2024 | 07:19 AM
lilorbie's Avatar
lilorbie
Before tearing the door apart I would squirt some white lithium grease into the lock cyl. from the outside and see what happens. That's what I had to do on my 1967 Mustang and the locks worked perfectly after that before the key would not move at all.
Old Feb 8, 2024 | 10:18 AM
Omni43's Avatar
Omni43
I shot some PB Blaster in it a week ago with no result; I'll give that a try. How long did it take before your lock freed up?
Old Feb 8, 2024 | 12:45 PM
Jim_K's Avatar
Jim_K
This may be a stupid question, but are you absolutely certain the keys are the right ones?
Old Feb 8, 2024 | 01:59 PM
lilorbie's Avatar
lilorbie
Omni43 Just a few minutes.
Old Feb 8, 2024 | 04:08 PM
Omni43's Avatar
Omni43
Yes, I'm sure.
flaref250
13
Aug 13, 2022 05:44 PM
Comanche1Star
Mar 29, 2009 05:47 AM
sacky07
Feb 8, 2005 07:33 PM
faroffthetrack
Jul 3, 2004 06:07 PM
RVBfordman
May 15, 2003 04:59 PM
