Door
Old Jul 3, 2004 | 12:44 PM
faroffthetrack's Avatar
faroffthetrack
Talking Door
Hey guys I need a little help removeing the door panel. Suggestions?
-Thanks
Old Jul 3, 2004 | 06:07 PM
omni's Avatar
omni
take all the visible screws out you can see,and theres one in the inside door handle where you grab to close the door, then pull on the panel ever so slightly, and look in the side of the panel so you can see those ribbed plastic clips, if you don't have the proper pry tool, use a flat screw drive and pop them out of there hole, once there all loose, (I think theres like 6 of them) lift the door panel up and off the top of the door, then you have to slide it forward to get it off the door handle, hope this helps, Randy
