Option Codes
Old Feb 21, 2002 | 05:31 PM
factofiction's Avatar
factofiction
Option Codes
Greetings,
I am the proud owner of a new to me 2000 excursion. I would like to discover all the options that were ordered by the origional purchaser. Are the codes stamped into a plate on the body somewhere? I know that other car companies do this and the procedure is easy to determin tall the options. I asked the dealer and he looked at me like I had three heads. Here is what I know so far: 2000 Excursion, V10, Limited, No sunroof. My main concern is to know what axel ratio was ordered to determine my max towing? But I really want to know everything ordered.
Thanks.
Factofiction
Old Feb 21, 2002 | 06:51 PM
Monsta's Avatar
Monsta
Sit. Stay.
Option Codes
Your axle codes are on the driver's side door jamb. On that data plate. Although, my codes aren't there . If yours aren't either, you'll have to go crawlin' underneath. I found the ratio's easier on the front axle. 3.73 denotes well...3.73.'s and 4.30's ....yada yada BUT if you have an L where the decimal point should be then you have the LS unit installed.
What others options do you know about that you are looking to see if you have?
Old Feb 26, 2002 | 10:34 PM
NoMo's Avatar
NoMo
Option Codes
Old Feb 28, 2002 | 12:37 PM
factofiction
Option Codes
Thanks for the information. I will crawl under and look on my axel to see what unit I have on my 4x4X.
I was hoping that Ford would be similar to PORSCHE. With PORSCHE there is a plate in the back that lists all the factory build options. This can be tracked to the original build sheets on file in Germany. It makes it nice when you are doing research for restoration purposes.
Old Mar 2, 2002 | 12:31 AM
3992824's Avatar
3992824
Option Codes
[updated:LAST EDITED ON 02-Mar-02 AT 01:32 AM (EST)]Don't know the codes, but the only options available on the 2000 limiteds were:
1. Heated seats
2. a CD changer
3. a limited slip rear axle
4. Choice of 3.73 0r 4.30 rear gear
5. Rear proximity sensor
6. Towing mirrors
7. All terrain tires
8. Transfer case skid plate (4x4)
Most are obvious, except the axle ratio/lmited slip. Any thing else that's on it was added by the previous owner, or the dealer.
P.S. the front license plate bracket is also listed as an option. Duh!
Old Mar 2, 2002 | 11:58 AM
Monsta's Avatar
Monsta
Sit. Stay.
Option Codes
And, of course, the engine.
Old Mar 2, 2002 | 08:03 PM
3992824's Avatar
3992824
Option Codes
Dang, I coulda hada V8!:-X11
Old Mar 2, 2002 | 10:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
Option Codes
You coulda; but why!
I actually saw a 4x4 Excursion with a 5.4L on the highway yesterday! I could only wonder why he ordered one with it????????
Old Mar 3, 2002 | 11:25 PM
3992824's Avatar
3992824
Option Codes
[updated:LAST EDITED ON 04-Mar-02 AT 00:28 AM (EST)]Did you spot the resonator and skinny tailpipe on it?
Check out ebay. There's a Paxton supercharged 5.4 Excursion up for sale. It looks like a Kenwood project vehicle.
Wonder why they didn't buy a V10 to tinker with?
Old Mar 4, 2002 | 12:09 PM
Monsta's Avatar
Monsta
Sit. Stay.
Option Codes
Yup.
I saw it and wondered the same thing...Nice looking truck though!
mwilliams0326
45
Apr 2, 2016 02:55 PM
DOOM173
Feb 27, 2016 07:18 AM
Garman3
Feb 1, 2016 05:11 AM
man-o-war
Oct 9, 2015 09:26 PM
RobertH
Jul 12, 2015 04:16 PM
