Ignition cylinder
Old Feb 5, 2024 | 06:44 PM
cole_burdine's Avatar
cole_burdine
2nd Gear
Ignition cylinder
I need an ignition cylinder for an 88 f150 but none of the ones I’ve bought will fit. Is there a way to tell if the column has been changed out for a different year model?
Old Feb 5, 2024 | 07:17 PM
My4Fordtrucks's Avatar
My4Fordtrucks
How does it not fit?
Old Feb 5, 2024 | 07:36 PM
cole_burdine
2nd Gear
It feels as if it gets tight and will not go in all the way
Old Feb 5, 2024 | 08:02 PM
wwhite's Avatar
wwhite
Alignment or your column is bad
Old Feb 6, 2024 | 03:39 AM
My4Fordtrucks
Was something wrong with the key? Why are you replacing the lock cylinder?
Old Feb 6, 2024 | 09:09 AM
Jim_K's Avatar
Jim_K
I seriously doubt that your column was changed-out, as that's a lot of work. (Edit: And it would probably be obvious.) And even if it was, the lock cylinder was the same P/N from 1980 to '91 or so.
Much more likely you're experiencing issues with the "timing" of the internal components (the rectangular opening you see when you take the cylinder out), and my guess is the issue is either there, or in the switch itself.
Here's a thought: Do you still have the old lock cylinder? If so, have you compared the new ones to it with a mic?
Gigemags05
Nov 22, 2017 05:16 PM
tdcouch
1997 - 2003 F150
Oct 25, 2015 03:14 PM
stil190
Mar 21, 2015 07:05 AM
spaytons
16
Sep 14, 2014 12:29 PM
Blitzcraig
Mar 5, 2012 10:45 PM
