Door Hinge Adjustment
Old Feb 4, 2024 | 03:40 PM
defdes's Avatar
defdes
I just replaced the pins and strikers and though I maintained the same hinge placement , doors are off. Is the body line and gap adjusted from the very hard to get to 3 bolt mount on the body, and the in/out leveling to face of fender/cab adjusted by the 2 bolts on the door?
Old Feb 4, 2024 | 04:10 PM
97-psd's Avatar
97-psd
They all work together for alignment. If you only replaced the striker and pins then I would start there and not mess with the hinge side
Old Feb 4, 2024 | 04:41 PM
defdes's Avatar
defdes
Door gap is tight at the bottom to the fender, and door raises up as it hits the striker to close.. Do I loosen the 3 bolts to the body on both hinges to fix that? It seems like the fender needs to come off to access all 3 of the top hinge body mounted bolts.
Old Feb 4, 2024 | 05:03 PM
96SD's Avatar
96SD
You can get a wobbly into the 3 bolt area its a pain and you may want to put some tape on the extension to protect your paint. I messed with my doors off and on for A LONG time before I was able to get it at least acceptable. Just decided that I was sick of it and just did it. Then when you change the door weather trim you get to mess around again but at least not as much.
bucks77ford
21
Mar 14, 2008 01:47 PM
1st Restore Project
Feb 14, 2008 09:20 AM
BGL
1978 - 1996 Big Bronco
May 31, 2005 09:44 PM
camccardell
Mar 7, 2005 05:17 PM
65styleside
Jun 30, 2003 11:41 PM
