Loose rearend
Old Feb 1, 2024 | 05:16 PM
Fball1208's Avatar
Fball1208
Loose rearend
So when I hit a bump in the road my whole truck gets real loose with the rear end kicking to the side. I know I need shocks but what else should I check. It’s bad enough it made me switch lanes the other day. Trucks an 09 long bed
Old Feb 1, 2024 | 08:17 PM
JKBrad's Avatar
JKBrad
Check the U bolt nuts, they could be loose, especially if a lift block was installed. Check the leaf springs for a broken leaf, check the bolts that hold the leaf springs to the hanger.
Also, check the pressure in your tires. Some guys put load range E tires on and think they need 80 psi of air. The proper inflation pressures are on the door jamb sticker.
Old Feb 2, 2024 | 07:19 AM
Fball1208's Avatar
Fball1208
Thanks. Definitely didn’t think of the leaf. No blocks have been installed it’s all factory other than the shocks which it’s on it’s second set.
Old Feb 2, 2024 | 09:56 AM
steve(ill)'s Avatar
steve(ill)
Shocks would be the BIGGEST cause of problem.
Old Feb 2, 2024 | 09:59 AM
JKBrad's Avatar
JKBrad
More than likely, especially if they are worn so bad that the pressure is gone. Shocks are probably the most overlooked suspension issue. Many people don't know that they are wear items and need to be replaced on occasion.
Old Feb 2, 2024 | 12:09 PM
Fball1208's Avatar
Fball1208
That’s what I’m hoping is the issue. Didn’t think they were that bad but maybe they are. I’ll see when the new ones get here
jini5
2021+ F150
Oct 8, 2023 05:30 PM
Eric Mahoney
2009 - 2014 F150
Dec 28, 2017 06:37 PM
1saxman
2004 - 2008 F150
Aug 14, 2017 06:51 PM
shaneinga
May 13, 2012 11:25 AM
mechelement
Sep 19, 2009 06:52 AM
