My '92 F250 has started showing the CEL intermittently lately, and since I've been down this road before with my F150 (jumping pins, counting numbers, checking codes, clearing codes, checking codes again....) without an OBD-I scan tool...
I'm getting tool old and cranky to count flashing lights again, so can someone please suggest to me a good OBD-I scan tool I can buy? I'm not afraid to invest in good quality tools, and I'll be driving the F250 into the ground, but I see too many OBD-I scan tools options out there so I'm looking for advice based on first-hand experience.
This is the one I was recommended when I asked about code readers
Originally Posted by renoyote
Junktownbill is right. That one works pretty well! I have one and it hasn't failed me yet.
Good info, and thank you for the recommendations!
Looking at the info for this scanner I see it doesn't read "live data". I'm pretty sure I know what this means, and to me this seems likely it would be useful under certain circumstances, so for those of you do this for a living, is this a useful feature/function to have?
I found an OTC scanner that does OBD-II as well, plus offers the live data streaming, for about $300. I'm not afraid to pay that, but if the live data streaming isn't useful, why spend the bucks?
Anyone?
Well im no expert, but theres a reason things went up to OBD2. OBD1 is kinda a guestimate and is much simpler, I'm sure live data is helpful, but OBD1 is limited by nature. Personally I wouldn't bother with it, and would use a voltmeter to test sensors if a code pointed me in that direction.
just my $.02
Code reading is not what you should rely on, that is a direction , not a solution, live DATA is what you need too see what the ECU is complaining about
Live streaming data isn't possible in the same way we are used to with OBD2 vehicles, It requires a module that connects directly to the PCM and intercepts the internal functions of the computer or one that connects between the PCM and wiring harness...Ford service had a system like this. There was also a device that somebody developed that could show some data via the EEC TEST connector but that functionality wasn't available on all OBD1 vehicles and I haven't seen mention of it in some time so it may no longer be available. Most of these devices have long since been declared obsolete or have suffered from parts shortages and been discontinued.
I have that one, absolutely love it and it works great. Only thing I would be concerned about is the prongs on top like to push into the scan tool, I put a coating of superglue around the bases of them to try to prevent it which has worked pretty well. I also bought the extension cable so I don't have to constantly put stress on those prongs and I can also run tests from inside the truck.
They still sell (Ford, Hickock, Rotunda) Star and Super Star testers on Ebay
If you were to get one of those used, you could follow the instructions for the self tests and all that verbatim from the service manual PCED
Here is mine
40 years old and still works
+1 on the prongs, or spade connectors on the innova tool pushing into the tool when plugging in . Mine did this as well. Like was mentioned earlier, I bought the extension cable and plugged that into the scanner. I don't remove it when I'm done with the scanner. Has been fine since doing that.
Perfect! I would prefer to read the data "live", but if I can't, or if it takes some obsolete or discontinued device, I guess I'll buy the standard scanner (of some sort) and call 'er good.
Here is mine
Nice!
There's one on eBay right now that looks pretty good, but the seller has zero feedback, which makes me hesitant to pull the trigger. There's a couple more I found, but they don't have the manuals, or at least they don;t call it out and I don't see them in the pictures or description, so this evening I think I'll order-up the Innova unit other people have mentioned, with an extension cable, and call it a day.
I use same scanner and love it. Pretty easy to use and I've had for around 2 hours and still works like brand new. IMO it's the best scanner for these trucks but some might say otherwise. If you're only going to use it every once in awhile it works great and it fits in the glovebox or center console.
