Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Looking for vin decode
Old Jan 31, 2024 | 09:48 AM
Wayne94gt's Avatar
Wayne94gt
4th Gear
Thanks for the info.
Old Jan 31, 2024 | 03:39 PM
85e150's Avatar
85e150
T80 = T800 gas
9 = 391 4V FT gas V8
U = Louisville Assembly Plant
471196 = 1964 numerical series, looks to be November 1963 production
212 = 212 inch wheelbase
J = Rangoon Red
T800 = '64-'67 T800 gas, hydraulic brakes, 43,000 lbs GVWR
181A = I do not have upholstery info for this year, but this is a conventional cab and chassis with tandem rear axles. (you knew that....)
4N
4 = Dana (Spicer) model 7231-D three speed auxiliary transmission
N = Dana (Spicer) model 5652 five speed direct main transmission (this code also used for NP435 but probably not in a T800)
(Does this truck have an auxiliary transmission?)
6E = Eaton model 34M rear axles, 34,000 lbs capacity, 8.60 ratio
No front axle listed. In '64-'69 only optional axles were listed, so this would be a standard axle probably without power steering. The axles have tags or numbers cast into them.
43000 = 43,000 lbs GVWR
199 3800 = 199 certified net HP @ 3800 RPM
14 = Pittsburgh District Sales Office
No special order.
Old Feb 1, 2024 | 10:35 AM
Wayne94gt's Avatar
Wayne94gt
4th Gear
Thank you. The truck does have the auxiliary transmission
KK560
Large Truck
Mar 6, 2022 08:54 PM
ymountainman
Large Truck
Jan 21, 2022 07:32 PM
wesjr
Jan 12, 2022 11:38 AM
Cliff Ragan
Sep 5, 2021 10:16 AM
