Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Help decoding vin/serial number?
Old Jan 28, 2024 | 09:36 PM
it’llhopefullyrun's Avatar
it’llhopefullyrun
1st Gear
I have a 1974 ford f-600 that someone replaced the drivers door on and I have no warranty tag, is there any way to figure out the truck’s options/specs from the vin?ViN: F60DCT32243
Old Jan 29, 2024 | 12:01 AM
85e150's Avatar
85e150
Welcome to FTE!
Short answer: No, not much.
Longer answer:
F60 = F600 gas, 4x2
D = 330 2V HD FT gas V8
C = Ontario Truck Plant
T32243 = 1974 numerical series, November 1973 production
Your transmission and differential will have info on them. Either tags or numbers/letters cast into the case. You may also find ratio info stamped in the carrier just above the pinion.
The VIN should be stamped on the frame also.
https://www.fordification.com/tech/vin_find.htm
Wheel type, two speed axle, 4 or 5 speed transmission would be things that matter imo.....
Manysal
Dec 1, 2023 03:03 PM
SFHVNFRMS
Large Truck
Jul 14, 2023 06:09 PM
Jthockey2
Large Truck
Jun 12, 2021 10:27 PM
Builder X
Dec 2, 2011 04:30 PM
Bigct59
Large Truck
Jul 19, 2010 05:00 PM
