Help NO START
Old Jan 26, 2024 | 06:23 PM
Grohol03's Avatar
Grohol03
1st Gear
Help NO START
Hello. 2004 f350 6.0 I’m not the best with the power strokes my wheel house is duramax. But I have a no start happened while they were out plowing truck just shut off. I went out put it on scanner saw ficm code and volts were way down when cranking. Got a FICM put it in was good but no oil pressure did HPOP and new seals on passenger to include dummy plug and stand pipe. Go to start have have 48v start cranking says I have sync ICP volts is 0.24 PSI take a little bit to get till 500 ipr % while cranking starts at 15 then goes to 85 and then goes to 35 in that 20 seconds or so the FICM voltage is down. Not sure where to go from here any thing would be much appreciated
Old Jan 26, 2024 | 07:32 PM
Maxium4x4's Avatar
Maxium4x4
Might help to list what previously has been done, clearly. What FICM did you use to swap out, is what I understood. Welcome to FTE and check through our Tech Folder for more information located at the top of this forum.
dragonheartt
Jan 11, 2023 01:47 PM
UnrealApp
Sep 8, 2016 02:05 PM
LasVegas F250
Oct 16, 2014 02:26 PM
JohnnyF350
Jul 12, 2014 05:56 PM
BobbyB
Sep 18, 2009 04:19 PM
