View Poll Results: What is the MAX boost a STOCK BLOCK ENGINE can safely sustain ?
40 psi
100.00%
50 psi
0%
55 psi
0%
60 psi
0%
65 psi
0%
70 psi
0%
75 psi
0%
80 psi
0%
85 psi
0%
More than 90 psi
0%
Voters: 2. You may not vote on this poll
2023/2024 6.7L Powerstroke MAX safe boost
Old Jan 26, 2024 | 04:53 PM
e173's Avatar
e173
4wd Low
Just curious.
What is the MAX boost, that the 2023/2024 6.7L Powerstroke can safely support ?
Assuming that you address all the problems outside the engine. You make sure:
- the injectors & fuel pump can keep up with the demand
- you can cool the engine, the air, the oil, the turbo etc.
- back pressure stays close to 1:1
- turbo can create that boost
- etc. - you address any other EXTERNAL problems that might arise.
What will be the MAX boost you can feed the engine before you start to have issues with a STOCK ENGINE ?
LIke: blown gasket, bent rods, cracked piston, rings etc
Even better, maybe you have an opinion on what will fail first? And at what psi ?
Of course this is not an exact science, so I will take educated opinions.
Or, you could just answer the poll.
Old Jan 26, 2024 | 07:36 PM
senix's Avatar
senix
40 psi since the gauge only goes to that. After that I believe you run the risk of lifting the heads and causing blown head gaskets,
Old Jan 26, 2024 | 09:41 PM
djousma's Avatar
djousma
I'm curious why you are asking here. who would actually know?
Old Jan 27, 2024 | 09:50 AM
e173's Avatar
e173
4wd Low
Because this is a forum. People come here to ask questions, share opinions, debate, discuss car/truck related news etc.
Like I said, I'm not asking for facts, I'm asking for educated opinions.
If you are asking why this thread, it's because I thought it's most appropriate. But if the moderators think there is a more appropriate thread, they can move it there. That's fine with me.
imjwm
15
Feb 6, 2016 07:37 PM
MikeSDK
Jul 13, 2007 05:30 PM
chadjones99
Apr 7, 2006 10:16 AM
crapr6
31
Oct 17, 2005 03:37 PM
jboard
Oct 6, 2005 07:55 PM
