Winch Wiring
Old Jan 23, 2024 | 05:30 AM
B-ManFX4's Avatar
B-ManFX4
The factory passenger side positive battery cable has a 6mm bolt in the exact spot you referenced, with several cables running to it. I figured if Ford did it that way it was OK to do the same on the driver side battery.
Here's mine. 6mm stainless bolt with a stainless flat washer underneath and on top. 1/0 welding cable runs from the passenger battery to an Anderson plug in the rear. 1/0 welding cable runs from the driver battery to an Anderson connector in the front.
1/0 welding cable connected with a marine-grade, tinned pure copper lug.
2 gauge jumper cables.
Old Jan 25, 2024 | 02:51 PM
rufushusky's Avatar
rufushusky
I went the stainless steel 1/4 bolts on mine for the power lines for the plow. Took all of 5 mins.
optikal illushun
49
Jul 25, 2023 11:20 AM
T. Banning
Feb 6, 2022 04:13 PM
Hartwig
Garage & Workshop
Feb 5, 2020 06:22 PM
Tylus
15
Jun 1, 2017 02:53 AM
TRENT310
Oct 26, 2014 02:46 AM
