Changing speedometer conversion constant in the EEC-IV- possible at-home?
Old Jan 21, 2024 | 12:41 PM
Jim_K's Avatar
Jim_K
According to the '92 Ford Owner's Guide, the "conversion constant" in the EEC-IV "can only be changed three times once the vehicle leaves the factory" (pg. 59). My F250 came with some wheels and tires that I'm not sure I'm going to keep, and the OD on the tire is 31.7" (nominal for LT235/70R17's).
(I just got back from Portland, Oregon, and haven't had a chance to wash it yet.)
I'm not sure what I'm going to do yet with regards to these wheels & tires, but my immediate question is: Is this "conversion" in the EEC-IV is something I can do?
Thanks.
Old Jan 21, 2024 | 12:53 PM
OBS460's Avatar
OBS460
There are several videos about the procedure to adjust your speedometer for different tire height. 3 times only is only half what I thought. I've done my 95 twice and it has 3 times left. If your 92 only has 3 maybe no one has ever adjusted it and you can be the only one who gets to.
Old Jan 21, 2024 | 02:09 PM
Jim_K's Avatar
Jim_K
I assume I can find these videos on Youtube (I haven't looked yet), but either way, good to know I can do this!
Thank you!
Jim
Old Jan 21, 2024 | 02:29 PM
Hit Man X's Avatar
Hit Man X
How far is the speedo off? I would consider that before wasting much time thinking about it.
Old Jan 21, 2024 | 03:01 PM
OBS460's Avatar
OBS460
You just need a set of alligator clips to ground the PSOM under the passenger side of the dash. Watch a couple of YouTube videos before doing it but keep in mind that actual rotations per mile and manufacturer advertised rotations per mile for ANY set of tires at a given air pressure are not going to match. I went from a 34.5" tire to a 33.1" tire and used Goodyear's rotations per mile number for my calculation and my speedometer ended up 5mph off at 60mph via GPS it was reading 65mph on my speedo.
Old Jan 21, 2024 | 03:14 PM
Jim_K's Avatar
Jim_K
(LOL!) I'm ashamed to admit I don't know yet! I haven't had it that long, and I prefer the mileage in my F150 so I haven't driven it all that much, but I just took it on a 1,700 mile trip, but didn't think to check the odometer against the mile markers (I'm Old School) until I was about 5-6 miles from home.
But I have another, shorter trip coming up in a couple weeks, so I'll check it then.
Just nice to know I can make a change once I figure out what I'm going to with these tires & wheels (too "new", and don't really go with the truck, in my opinion).
Old Jan 21, 2024 | 03:19 PM
Jim_K's Avatar
Jim_K
Thank you! I'll do some digging around on Youtube this week and see what this entails.
And who knows? Maybe it's "good enough" as it is right now, I don't know. But I have my doubts, as these tires "look" shorter than other F250 tires I've been looking at while driving around.
Old Jan 21, 2024 | 04:20 PM
rla2005's Avatar
rla2005
I believe the PSOM can be reprogrammed 6 times before it goes into lockout.
Great info from Steve83 here:
https://www.supermotors.net/registry/2742/69150-2
Old Jan 21, 2024 | 05:37 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Jim_K
My F250 came with some wheels and tires that I'm not sure I'm going to keep, and the OD on the tire is 31.7" (nominal for LT235/70R17’s)
Not as nice as the factory Alcoas but they aren’t terrible. How does that size combination compare to what is listed on the B pillar?
I certainly would not waste a calibration change for something you might not keep. I would see how far it is off and keep that in mind when driving. That’s what I did when I put 35’s on the Bronco.
Old Jan 22, 2024 | 05:34 AM
manicmechanic007's Avatar
manicmechanic007
I am not sure that 92 has a PSOM
But if it does, it sure is easy to change (or find out if you are out of changes)
It was 3 times IIRR
Rule of thumb is 5 seconds at 60 mph
If you are off less than that, a driven gear change or PSOM adjustment is not needed as you will be off the other way
Old Jan 22, 2024 | 06:50 AM
rla2005's Avatar
rla2005
Yes it does have a PSOM. The first year that Ford used it on this vintage truck.
1992 F-Series/Bronco VSS diagram.
Old Jan 22, 2024 | 07:52 AM
AuroraGirl's Avatar
AuroraGirl
rip steve, wish I knew what he did to get banned here lol... I left the other ford truck forum because hes knowledgeable yes but hes quite the blowhard.
Old Jan 22, 2024 | 09:59 AM
Scndsin's Avatar
Scndsin
PSOMs are generally available for cheap & interchangeable across years.
Pick up a couple & test till you find your correct programing.
Then put your original back in.
Old Jan 22, 2024 | 10:21 AM
torq'ta 5 8's Avatar
torq'ta 5 8
ch1gg1ns
Large Truck
Jul 12, 2023 01:19 PM
swjtlongdrive
Mar 22, 2016 04:11 PM
allstarkmt
Feb 27, 2007 12:56 PM
Rengaw
Feb 21, 2005 11:12 AM
