Firewall ID number
Old Feb 4, 2024 | 02:45 PM
mtflat's Avatar
mtflat
Curious stuff... that flex tube and filler cap is not stock. It was likely put on there to prevent blow-by from the crank case getting into the cab. Been there, done that.....
I have an engine torn apart that needs pistons and rings from excessive blow-by that filled the cab with blue smoke when I would stand on the pedal. I had to run with the windows down so I could see.
All 8 pistons destroyed and all compression rings broken. I ran high-compression heads and drove the snot out of it. That's the price you pay for performance. Fortunately, no damage to cylinder walls.
Normally that stand pipe has a cap that draws air INTO the crank case. The road draft tube that runs down beside the water pump is where compression gasses should escape from the crank case.
Old Feb 4, 2024 | 04:42 PM
Zeekracing's Avatar
Zeekracing
4wd Low
I seen one like this on a model A also.
leonharu
Sep 8, 2023 09:09 AM
mozart
17
Jan 31, 2010 06:20 PM
leonharu
Jan 15, 2008 06:58 PM
voltson
Jun 6, 2007 10:14 PM
GreatNorthWoods
43
Nov 3, 2005 07:36 PM
