Vibration, bad flywheel?
Old Jan 18, 2024 | 06:43 PM
Jamon Norton's Avatar
Jamon Norton
I have a 1999.5 F250 super duty with the ZF6 manual. It has a newly remanufactured transmission, rebuilt, driveshaft, rebuilt rear end all within the last 20,000 miles I am still having an issue with a vibration upon takeoff most noticeable in low first second gear, I am running out of parts to change in the driveline. I am thinking the only thing left is a flywheel issue looking for opinions and other people that have had flywheel problems to chime in.
Old Jan 18, 2024 | 07:01 PM
pvdiag's Avatar
pvdiag
A flywheel issue would likely be felt in the pedal as you are engaging the clutch. Another other thing would be the center bearing support on the driveshaft if you have an extended or crew cab.
Old Jan 18, 2024 | 07:03 PM
Wes444's Avatar
Wes444
Was the transmission before or after the vibration?
Wondering if they got the driveshaft out of time during that job and you've been chasing it ever since if the vibe was there beforehand
Old Jan 18, 2024 | 09:40 PM
udsuth78's Avatar
udsuth78
Sounds like axle wrap. The rear leaf springs are flexing from the torque and throwing off the drive line angle.
Old Jan 18, 2024 | 10:55 PM
Jamon Norton
drive shaft was done same time as trans
how do you check to see if drive shaft is in time?
Jamon Norton
I have new leaf springs front and rear and omg traction bars
Old Jan 18, 2024 | 10:57 PM
Jamon Norton
it is extended cab the center support bearing has probably 80k on it
Old Jan 18, 2024 | 10:58 PM
Jamon Norton
Also does it worse towing my trailer in low,1,2 gear uphill
Old Jan 18, 2024 | 11:07 PM
udsuth78's Avatar
udsuth78
This is very characteristic of axle wrap. Taking off from a dead stop, pulling a hill at slow speed, or loaded are instances of high torque loads being exerted on the springs. The fact that the springs are new is irrelevant. New springs flex it's kind of their job.
Old Jan 18, 2024 | 11:45 PM
97-psd's Avatar
97-psd
What brand of clutch and was the flywheel surfaced when the new clutch and trans were installed?
Old Jan 19, 2024 | 05:53 AM
Wes444's Avatar
Wes444
I can't find any hits for omg traction bars, do you have a link or seller's website?
Old Jan 19, 2024 | 07:44 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I had a similar issue and was chasing axle wrap for quite a while. I installed new leaf springs, shocks, air bags and lastly OUO traction bars. The traction bars helped so much I thought it was cured.
The shudder was still there, but only starting in low or reverse in low with the 38' fifth wheel attached. I called Dave at OUO and he said "sounds like clutch chatter". Turned out the flywheel had hot spots on it that would cause the shudder/chatter.
A fresh clutch and resurfacing of the flywheel resolved all the issues and it has been smooth as silk ever since.
A couple of videos I made up while diagnosing the shudder are below.
Old Jan 19, 2024 | 08:35 AM
Jamon Norton
Video describing driveshaft phase
I think it auto corrected it was supposed to be pmf
Jamon Norton
I’m pretty sure they didn’t do anything to the flywheel when the clutch was installed 80,000 miles ago….. mechanic said it looked fine, but I had lots of problems out of everything he did so idk that I believe him
Old Jan 19, 2024 | 08:37 AM
Jamon Norton
https://youtu.be/9asHJ4ggT_8?si=puSZwQMbdaemcQIU
https://youtu.be/uqQY5g4KrGo?si=3hN_Ek6lKTl1QsCT
it sounds exactly like what your truck is doing in the first video. So does this mean I can just change the flywheel as long as the clutch is in good shape or am I going to have to buy another South Bend clutch? I have the heavy duty dual disc rated for 550 hp.
