clutch adjustment
Old Nov 23, 2003 | 09:28 PM
87 xlt lariat's Avatar
87 xlt lariat
clutch adjustment
i have a '87 f-150 4x4 5.0 efi. 4speed manual.with hydraulic clutch.
is there any way to adjust the clutch,clutch seems fine in 1st,2nd and 3rd but in high gear seems as if it's getting weak.have no idea how old clutch is.truck has 127k on it.
Old Nov 23, 2003 | 10:43 PM
steve83's Avatar
steve83
The hydraulic clutch linkage is self-adjusting, and it doesn't change with gears. Anything related to what gear you're in has to be inside the transmission, because the shifter isn't connected to the pedal in any way. The master & slave cylinders are plastic, and they sometimes crack, allowing greater play than they should have. Get an assistant to work the pedal while you crawl under and inspect. (Use tire chocks & the e-brake!)
Axel87
Nov 14, 2015 12:26 PM
Ford Guy87
Feb 13, 2015 03:48 PM
keyul
Nov 13, 2007 11:33 PM
97 HD
Jul 12, 2007 05:06 PM
str8six
1978 - 1996 Big Bronco
Oct 1, 2002 05:22 PM
