Overload spring question
Old Jan 15, 2024 | 05:46 PM
GetMore's Avatar
GetMore
I was surprised to see that my '24 F-250 CCSB gas has an overload spring.
I do have the 5th wheel prep, and >10,000 lb. GVWR (10,500 to be exact), but no plow or camper prep.
Is this normal? I wouldn't be surprised if it was an F-350.
Old Jan 15, 2024 | 06:01 PM
4wd6.7L's Avatar
4wd6.7L
Pretty sure the >10k pkg is the reason for the overload. Is it 4 total leafs? A 350 has 5 total leafs.
Old Jan 15, 2024 | 07:03 PM
GetMore's Avatar
GetMore
Yes, four leaves. Two eyeletted main leaves, the thick, flat bottom leaf, and the single overload.
I had been under the impression that the difference between F-250 and F-350 was the overload, and that they both had two main leaves.
Old Jan 15, 2024 | 07:19 PM
4wd6.7L's Avatar
4wd6.7L
The 350 has 4 leafs (3 plus bottom overload) in the main pack plus a top overload leaf that Ford calls an auxiliary spring. The base 250 pack is 3 leaf (2 plus bottom overload).
icrman
Jul 27, 2022 02:16 PM
HGaither
Feb 22, 2022 03:48 PM
BIGTRUCKBIGRV
Aug 17, 2011 02:50 PM
fordpowerstroke444
Jan 1, 2011 02:10 PM
Dustin_86
Jan 20, 2005 09:56 PM
