7.3 Will Not Start
Old Jan 14, 2024 | 05:35 PM
visiongrill's Avatar
visiongrill
4wd Low
7.3 Will Not Start
I have a 22 7.3 gasser. Starting this fall, when the temperature is somewhere around 25 degrees or less, the truck will not start.
I have taken it to the dealer twice, first time "could not duplicate", second time they replaced the battery. That was maybe 2 weeks ago.
Now its -15 where I am at in Iowa and the damn thing won't start. Battery seems good. Truck just cranks until it times out. When it's a little warmer, it will eventually start with rough idle and RPMs going up and down for a couple of minutes.
Has anyone else seen this issue? I have been searching here but haven't found anything useful.
Thanks for your help.
Old Jan 14, 2024 | 05:37 PM
pappcam's Avatar
pappcam
It's a 22. It's under warranty. Find a dealer who will fix it.
Old Jan 14, 2024 | 06:12 PM
TARCHER's Avatar
TARCHER
Im in northern canada. my 2020 has never let me down. At minus 4 f I plug it in
Old Jan 14, 2024 | 06:17 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
If the engine turns over then it is NOT the battery, dealer tech was STUPID!
If it cranks and doesn't start, then either there is no spark, or no fuel being injected as it should be.
I would find a different dealer to take it to.
Old Jan 14, 2024 | 07:21 PM
Just Chilling's Avatar
Just Chilling
Not necessarily, I have had multiple fords with gas engines that if the battery was weak it took all the juice to crank and didn’t spin fast enough to start and or didn’t have any left over for spark. It would come on slow enough that after the battery was replaced you wondered why you waited so long.
Old Jan 14, 2024 | 07:27 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Not on the truck in question, the PCM will not allow the starter to engage unless there is sufficient amps to start the engine.
And, it has that, he said it cranks until it times out, plenty of battery power.
Old Jan 14, 2024 | 07:44 PM
camperfanatic01's Avatar
camperfanatic01
Lots of good things to think about on this page:
https://neeseautomotive.com/car-wont...g%20and%20wear.
Old Jan 14, 2024 | 08:01 PM
Just Chilling
You might be right on that, these were older ones that did not have all this stuff.
Old Jan 15, 2024 | 05:24 AM
senix's Avatar
senix
what about spraying a little starter fluid into the air cleaner to get it started?
Agree this is not the answer and a better dealer is. I would leave it overnight so they can duplicate the problem.
Old Jan 15, 2024 | 11:22 AM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hi there. Feel free to send us a DM with your vehicle's VIN and mileage. We'd be happy to look into this for you.
Old Jan 15, 2024 | 12:31 PM
TARCHER's Avatar
TARCHER
If its really you, good to see ford paying attention to issues.
Old Jan 15, 2024 | 12:42 PM
visiongrill
4wd Low
Can you prove you are from the Ford Motor Company?
Old Jan 15, 2024 | 12:45 PM
visiongrill
4wd Low
I personally think it's a fuel issue. Currently waiting for a tow. Might be a while with all the cars off the roads the last few days.
Old Jan 15, 2024 | 12:46 PM
visiongrill
4wd Low
Once I can get it moved that is what is going to happen.
Old Jan 15, 2024 | 02:42 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yes, @Ford Motor Company is the ford forum rep, I have given them my info on past repair issues and they have hooked me up with a Ford customer rep and helped get my issue handled faster.
They are who they say they are.
Send them a message with your truck and dealer info.
