Oil pan issues
Old Jan 13, 2024 | 07:55 PM
Mike M.'s Avatar
Mike M.
3rd Gear
Oil pan issues
I have a 79 f150 ranger xlt 4x4 with a 400 Cid engine.oil pan is a front sump so when draining,oil hits the dif and makes a mess.other than the mess should I change to a rear sump and pan to avoid any other problems from having a front sump and pan?the engine i believe is a 1980 and has just been rebuilt and I haven't installed engine yet.i didn't know if it's possible that the pan could possibly be damaged by hitting the dif or any other front-end parts because it's a front sump and pan.
Old Jan 13, 2024 | 08:03 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Should be a rear sump oil pan in the 1st place. 2wd got a front sump. If you replace the pan you also have to change the pick up tube and the stud to attach it to. Easier to make a cardboard funnel/shield to direct the oil away from the diff. Or take a large funnel and cut a 1/2 moon out of the upper lip edge and put it in there as a redirect to your oil catch pan. Make sense?
If you off road it hard, yes you can hit the oil pan on a front sump swapped in 460 with the front axle differential. It only put a dent in the pan, no hole.
Old Jan 13, 2024 | 08:25 PM
Mike M.'s Avatar
Mike M.
3rd Gear
[QUOTE=77&79F250;21098157]Should be a rear sump oil pan in the 1st place. 2wd got a front sump. If you replace the pan you also have to change the pick up tube and the stud to attach it to. Easier to make a cardboard funnel/shield to direct the oil away from the diff. Or take a large funnel and cut a 1/2 moon out of the upper lip edge and put it in there as a redirect to your oil catch pan. Make sense?
Old Jan 13, 2024 | 08:26 PM
Mike M.'s Avatar
Mike M.
3rd Gear
No just locking it in if it gets stuck on the farm nothing major
Old Jan 14, 2024 | 01:19 PM
lasermike's Avatar
lasermike
If you have room for it, a Fumoto valve or similar could be a game changer.
Here I'm draining the engine oil while parked on carpet.
Michael
jack orchard
May 21, 2017 05:40 PM
smittyhunter84
Oct 23, 2011 08:28 PM
factory594x4
Nov 14, 2006 03:09 PM
ol' yeller1
Oct 24, 2004 10:56 PM
rick
Dec 15, 2001 07:48 AM
