What heads, & what done to block. Going Boarding said-->"Is the piston down in the hole, even with the block deck, or protruding? If it's a never been touched bottom end, probably in the hole a touch or even with block. I would measure, then subtract that value from 0.040" and pick a gasket that is that thick. If it's at zero deck height, that is, pistons even with block deck, use a 0.039" or 0.040" compressed gasket. That's stock from everything I've seen. You're setting your squish right now, this will dictate resistance to ring & piston destroying detonation. Too loose and you lose the quench effect, which can equate to even a low compression engine being detonation prone. Some would say to go tighter, maybe even as low as 0.030"
Quench is extremely over rated and a few thousandths one way or the other isn't going to make any difference. You're not going to change that enough to worry about in a stock engine using a stock replacement gasket.
It's a stock block and un-assembled at this time, cylinders bores style has the factory cross hatching so replacing with standard sized rings. Using a crank from another motor because the original had scored journals, just want to order up all the parts but was getting confused by different compressed thicknesses..thanks for the replies..
