I’ve had an intermittent issue with my OD light flashing, truck going into limp mode, and P0500 code. I can’t seem to track it down. VSS looks to be working. I installed the trans brand new and it has almost zero miles on it. I pulled the PSOM and didn’t see any issues with the wiring or circuit board. Speedometer and tach work fine. I have a breakout box for pin testing if I need to. I just don’t know where to go from here. I’m not a transmission specialist by any means, but this is the last thing keeping this project off the road. Any help is greatly appreciated.
Take a look at the wires going to the VSS. The speedo on my 96 C&C quit, and although the wires looked good, one had failed/broken beneath the insolation.
Thank you. Wires look good and speedometer and tach work fine.
Update. I found the short. It was behind the passenger side kick panel just above this ring terminal for the ground screw. I’ll fix and let y’all know if it works.
