1996 F250 NEEDS HELP
Old Jan 9, 2024 | 11:40 AM
Mckdeznuts's Avatar
Mckdeznuts
1st Gear
my 1996 ford f250 won't start, sounds like its misfiring. replaced the fuel pump, the distributor, throttle positioning sensor, map sensor, ecm, spark plugs and wires, egr valve, idle positioning sensor, ignition switch, duel tank switch but still won't start. When it was running it was acting strange it was hesitating or jerking when I would accelerate faster and then would have my gas pedal all the way down but wouldn't have any power. I have tried everything I could possibly think of and don't know what else to do. So any thoughts and ideas will be very much appreciated
Old Jan 9, 2024 | 02:48 PM
350Recon's Avatar
350Recon
https://www.ford-trucks.com/forums/forum28/
Click on the above link it will lead you to a more helpful area for your year of truck.
Old Jan 9, 2024 | 02:49 PM
350Recon's Avatar
350Recon
Could the injectors be clogged?
Old Jan 10, 2024 | 08:03 AM
85e150's Avatar
85e150
Thread moved to the forum for this truck.
Can you do a vacuum test?
How many miles?
Timing chain ever replaced?
What engine?
Old Jan 11, 2024 | 08:05 AM
manicmechanic007's Avatar
manicmechanic007
Codes are your friend
Especially on that 96
Check the fuel pressure with a gauge
Perform an injector noid light test
rkillian
Jul 15, 2021 06:01 AM
warrenraymond
Feb 26, 2018 08:14 PM
96fun150
Sep 29, 2015 08:59 PM
cj7taz
Feb 13, 2004 08:49 AM
