Regulator wire
Old Jan 9, 2024 | 03:46 PM
gweedo295's Avatar
gweedo295
Originally Posted by BHoffa
I see you have a Mallory Unilite distributor, I worked at Super Shops back in the day and we sold Mallory products. The Unilite module is a good design and very accurate, but if you have a bad ground you will kill the module and it will make you a pedestrian. Also don't try to disconnect the battery while the engine is running because that will also kill the module. I don't know of a way for you to check to see if the module is bad, at Super Shops we had a ignition system on the counter and we could connect the customers distributor or coil and determine what needed replacing. Unfortunately I have replaced a lot of these Unilite modules for customers.
Brian
yeah tested the coil n module both check good. I cleaned all connections n new ground. Went over testing on the phone. I have a coils coming but sending it back, guys says very rare for coil failure. So o am going to replace the module n c what happens. Thnx for the info. Neutral safety switch is ok too
Old Jan 9, 2024 | 07:09 PM
crazy96863's Avatar
crazy96863
I can’t speak highly enough of switching the distributor system over to Pertronix. This gets rid of everything ignition related other than the coil and the distributor. It simply requires on key on hot wire. Simple. Reliable. And it looks good.
This is comparable to switching over to the 3g one wire alternator modification. A must do as far as I’m concerned.
Old Jan 9, 2024 | 08:45 PM
redroad's Avatar
redroad
Do you have any thoughts on the red wire from the regulator to the fuse box. is that supposed to be connected to hot?
The "S" on your regulator plug, the "Red/Grn" wire, goes to your ignition switch only when you have gauges (Ammeter) in your instrument cluster.
The "I" on your regulator plug is the "Red/Grn" wire when "Idiot lights" are used in your instrument cluster.
Old Jan 10, 2024 | 05:33 PM
1TonBasecamp's Avatar
1TonBasecamp
What Redroad said. So let's get it out there first, whether your truck has an ammeter in the cluster, or a battery light?
I see you have a new regulator connector. It's got all the wrong colors on it, but that's typical of the import aftermarket over the last few decades. But the critical thing is that, if you have a light, the regulator connector has the four wires as yours does. If it's got an ammeter, it only uses three.
And no, there is never (from the factory) a wire running from the regulator to the fuse panel. In either scenario...
And no, unless it's been hacked together, your regulator being mis-wired or not, won't have any effect on the coil sparking.
Have you verified that the distributor rotor is turning when the engine is cranking? You can test this easily with the cap off and either turning the engine by hand or by the key.
And the NSS will ONLY effect the starter cranking. Nothing at all to do with the ignition not sparking.
But a bad starter relay can effect this, as can a bad radio noise suppressor on the coil's positive wire.
You can eliminate the starter relay as the problem by disconnecting the Brown "I" wire and leaving it disconnected while testing. Same for disconnecting the radio noise suppressor. If it's still there.
Usually those things disappear when a new coil is installed.
Paul
boone13
Aug 21, 2018 09:47 PM
Pastor Dale
Nov 21, 2014 01:00 PM
69highboy69
Dec 22, 2012 03:06 PM
lurch460
2004 - 2008 F150
Jul 10, 2012 06:04 AM
GOTH_TRUCKER
Electrical Systems/Wiring
Sep 6, 2006 04:40 PM
