Help please
Old Jan 5, 2024 | 04:40 AM
Igor M.'s Avatar
Igor M.
Help please
Hi everyone.
just wondering if anyone knows what the solenoid in the pic is.
Looks like it has not been connected for some time.
Cheers in advance
Igor
Getting on with pulling the old girl apart...
Old Jan 5, 2024 | 10:22 AM
1TonBasecamp's Avatar
1TonBasecamp
Can you get a picture from a different angle, perhaps, from the side?
I don’t recognize it at all, but if that is an electrical connection on top with the nuts, it’s probably just a fuel selector valve. Switches between two tanks.
Does your truck have two tanks, or just one?
And frankly, if it’s a tank switching valve, it would have three hose connections. If it’s got just two, then, perhaps it’s a shut off valve instead.
But from this angle, I don’t think I’ve ever seen one like that.
Old Jan 5, 2024 | 10:23 AM
1TonBasecamp
By the way, what year and model truck is that?
Old Jan 5, 2024 | 10:51 AM
kenny nunez's Avatar
kenny nunez
Solenoid?
It looks like a temperature sender that may have been for transmission cooling.
Old Jan 5, 2024 | 12:00 PM
'65Ford's Avatar
'65Ford
If that's the only odd piece, it will be hard to guess. Looks like your truck was set up to transfer some liquid for some reason.
Is that a pulley on the driver side of the engine? What does it do?
Old Jan 5, 2024 | 02:34 PM
Jim_K's Avatar
Jim_K
All I can add is that it's not original.
If it is indeed a solenoid, perhaps it was part of an anti-theft, fuel shut-off system.
Old Jan 5, 2024 | 02:38 PM
1TonBasecamp
Looks like simple plumbing fittings. Maybe the thing on top is an electrical sensor, like Kenny was saying, threaded into a reducer bushing, threaded into a standard T-fitting.
Old Jan 5, 2024 | 04:29 PM
Igor M.'s Avatar
Igor M.
Yeah Hi mate
it's a 71 f250
Old Jan 5, 2024 | 04:49 PM
Igor M.'s Avatar
Igor M.
Thanks
Originally Posted by Igor M.
Hi everyone.
Cheers in advance
Igor
has 2 tanks, manual type switch by the seat on the floor, and a electric switch on the dash
Old Jan 5, 2024 | 04:50 PM
Igor M.'s Avatar
Igor M.
If it's not original, I'm getting rid of it.
Old Jan 5, 2024 | 05:47 PM
FuzzFace2's Avatar
FuzzFace2
when you get it out take another picture so we get a better look at it
Dave ----
Old Jan 5, 2024 | 06:04 PM
Igor M.'s Avatar
Igor M.
Dave ----
Will do cheers Dave
Old Jan 5, 2024 | 06:05 PM
Igor M.'s Avatar
Igor M.
Pulley is power steer pump
Old Jan 25, 2024 | 04:43 PM
Igor M.'s Avatar
Igor M.
Ok here it is.
Old Jan 25, 2024 | 04:45 PM
Igor M.'s Avatar
Igor M.
Some sort of sensor. Not a solenoid.
