Poly Motor Mounts
Old Jan 3, 2024 | 08:57 PM
Biggest Red's Avatar
Biggest Red
5th Gear
Poly Motor Mounts
Wanted to see if anyone knows of other options for 1996 f150 302: the two I have found (commonly recommended on this forum) are the bronco grave yard's Extreme Duty Poly Motor Mounts ($115 .. sold out of course...) and the AutoFab mounts (https://autofab.com/product/80-96-fo...-motor-mounts/) at $380 which feels like a ridiculous price
Cannot find any other poly motor mounts on google or on the forum ... but they must exist?? ...hopefully for less than $380!!
Thanks for the help!
-Alex
Old Jan 3, 2024 | 09:52 PM
Prototypemech's Avatar
Prototypemech
I have 2 experience with polyurethane mounts, and they were both negative.
Automotive polyurethane is very stiff, about the durometer of a 5 gallon bucket or a hockey puck. They also squeak. It transfers vibrations and noises very well.
I'm not sure what application you're using them for, but I would suggest sticking with rubber mounts, so you can listen to your radio while driving.
Old Jan 4, 2024 | 12:12 AM
TexasGuy001's Avatar
TexasGuy001
What Proto said. Unless your building a hot rod or trail rig, I would avoid them. Have had them on a Mustang and there is a noticable difference in vibration. Whatever you do don't get a poly transmission mount, that is much worse.
Old Jan 4, 2024 | 12:38 AM
F350JOHN's Avatar
F350JOHN
I highly recommend these. They are a stupid simple, strong design. Baja tested and proven. Very nice build quality.
https://solomotorsports.com/shop/par...-motor-mounts/
Old Jan 4, 2024 | 02:18 AM
TexasGuy001
Those look like well made motor mounts and would probably be great for the right build. I'm not sure they are necessary for a stock or nearly stock truck. The ones I have on a warmed over Mustang are similar.
Old Jan 4, 2024 | 08:10 PM
PRIMERED79 SHORT BED's Avatar
Are these not the ones bronco graveyard sells? I have the same set that i'm putting under my 362w build.
Old Jan 4, 2024 | 10:10 PM
F350JOHN's Avatar
F350JOHN
They are nearly identical. But not the same. However, It does appear they are less expensive! Which is a plus!
Old Jan 5, 2024 | 09:13 AM
Mikulh's Avatar
Mikulh
I used the Bronco Graveyard Poly motor mounts on my truck, and have no complaints. (I realize that doesn't help with them being sold out... just saying I don't find poly mounts to be to harsh or cause too many vibrations.)
schefner
Apr 24, 2008 07:29 PM
peppersfords
1978 - 1996 Big Bronco
Mar 23, 2007 12:54 AM
Gary E
Mar 1, 2007 02:22 AM
85bronco
Aug 6, 2001 09:37 PM
