Manual or electric choke?
Old Dec 30, 2023 | 10:26 PM
turbosocal's Avatar
turbosocal
4wd Low
My truck has a Holley 4bbl carb without a choke. I'm finding it's a pain in the *** to start (requires multiple throttle pumps, multiple cranks, and needs throttle feather to keep it from dying until warm. Once block is warm though, starts right up) and want to install a proper choke, but not sure whether to just do manual choke or go with electric. Any thoughts? Is this an easy install for an amateur?
Old Dec 30, 2023 | 11:22 PM
resonateur's Avatar
resonateur
I would think the carb should have a choke housing on it already? Electric....
Old Dec 31, 2023 | 05:19 AM
AZSCAWPION's Avatar
AZSCAWPION
One of the best things I did was convert my Holley to a manual choke.
Old Dec 31, 2023 | 07:13 AM
wtx66f100's Avatar
wtx66f100
Given a choice between electric versus manual choke I prefer manual because I can control the amount of choke myself.
Old Dec 31, 2023 | 08:20 AM
Crop Duster's Avatar
Crop Duster
Post a picture of your carburetor. There are performance versions that do not have provisions for a choke at all. And if your carb has a choke tower it will depend on how many parts were removed and the model of your carb to know if it is going to be economical to replace them.
Here is a link to Holley's choke components. Search The Holley Website
Old Dec 31, 2023 | 08:58 AM
BobbyFord's Avatar
BobbyFord
Electric. Set it right and then forget about it.
Old Dec 31, 2023 | 02:42 PM
KO1960's Avatar
KO1960
If you already have the cable and **** for a manual choke, I would try to make that work. If not, electric choke will be easier.
Old Jan 1, 2024 | 08:01 AM
User 71024's Avatar
User 71024
I have manual choke in my '55 Tbird, my '76 CJ, my '65 E-Pup, and will have it in all of my builds. I like simple. I drive my cars every day and never have to adjust the choke. I always found automatic chokes to be seasonal, I could never seem to make them work year round properly, seems I was always tinkering with them, or settling for them not being quite right.
Old Jan 1, 2024 | 08:25 AM
FuzzFace2's Avatar
FuzzFace2
Crop Duster is right on some Holley's dont have a choke.
The early Holley HP carbs just removed the butterfly and linkage for better air flow.
Later Holley HP carbs they milled off the choke horn for even better air flow so there is no way to even put a choke on this carb.
Now after owning Holleys with full electric chokes they can be a hand full on how they work.
They stay on to long and load up by running to rich or come off to soon and stall. All is good when up to temp.
I do have older Holley that uses hot air for the choke that works pretty good.
Cant remember if it also has electric with the hot air?
I did have 1 motor with a Holley 2300 v2 carb that had a manual choke and got to say that worked pretty good as it was on a 4x4 and used in the winters in New England.
So for me it depends on what the carb has for a choke on it now and how much I want to mess with it to get it to work some what right LOL
Dave ----
Old Jan 1, 2024 | 08:56 AM
AZSCAWPION's Avatar
AZSCAWPION
Exactly right.
Also an anti theft device. I remember one winter day some time ago, my oldest was being a wise *** and told me he could drive my truck whenever he wanted or something stupid like that. Bet him $20 he couldn't even start it. He very wisely declined.
Old Jan 2, 2024 | 04:55 AM
'65Ford's Avatar
'65Ford
The one electric choke I've had was opened and closed based on position of the ignition key and how long the key was in that position. I felt that was not suitable for all weather so I converted to manual.
Perhaps more important is having a fast idle capability. Using the manual choke cable in conjunction with the gas pedal, I can choose a couple different fast idle rpms. This is nice for warming up an engine before trying to drive.
BeauF0RD
47
May 19, 2019 05:47 PM
67FEranger
Dec 12, 2012 03:28 PM
lucky_strike
Sep 21, 2010 05:35 PM
dj53
26
May 5, 2005 06:31 PM
boomer202
Jan 11, 2004 09:41 PM
