Compression test, what am I doing wrong?
Old Dec 29, 2023 | 07:14 PM
calvinhg's Avatar
calvinhg
I'm trying to test compression on my 7.3 but it seems the adapters I have just aren't working. I have both a snap-on adapter (the long one) and a harbor freight adapter (the short one).
I've tried 3 different cylinder (2, 4 and 6) and they're all the same. Nothing shows up on the gauge. I also tried a different gauge, still nothing. Very rarely it shoots up to 200psi on the first compression stroke and then nothing. I had the intake rocker off at first but now I'm testing with it on.
I tried to screw just the adapter in with no gauge or schrader valve and see if it blows out. It did on the little adapter, but I can't get a hose on it when it's in place. The long adapter does nothing. I tried changing out the o-ring too.
I have seen the compression test procedure in the 7.3 tech folder. Should I just get that little pipe thread to 10mm adapter and a grease hose, and make the adapter myself?
Old Dec 29, 2023 | 07:38 PM
FordTruckNoob's Avatar
FordTruckNoob
Yes.
Old Jan 2, 2024 | 11:04 AM
calvinhg's Avatar
calvinhg
Found the issue, the hydraulic lifter was pumped up and not allowing the intake valve to close all the way. I let the engine warm up and I finally got it to work (with the setup from the DIY)
99f350cclb
22
Dec 17, 2021 11:42 AM
daveengelson
Garage & Workshop
Feb 8, 2020 11:50 AM
Dobies4life
May 12, 2014 10:14 PM
Dan V
33
Apr 9, 2014 08:37 AM
dougbrown
20
Feb 5, 2012 07:32 PM
