Weak spark? plz help
Old Dec 28, 2023 | 08:58 PM
thepipman's Avatar
thepipman
7th Gear
Angry Weak spark? plz help
Hello, I have a 94 f-150 5.7 that has been sitting for over a year, deciding to fix it. i check for spark which it didnt have, replaced the ignition module, has spark, very weak still not starting, i said **** it and purchased a new coil, wires, and a distributor, only for the spark to still be "weak"??? using a spark tester i noticed light that should be bright is pretty damn dull i also noticed after starting it multiple times the ignition module gets hotter then hell... Something i found the most weird!! when i leave key on and NOT start i can put a screwdriver to the coil and it will still make that zap and you can see current going to my damn screwdriver, but when i put a test light off of ground of battery in to the yellow control wire of the ignition coil then put the screwdriver back on.... no zaps. im concluding its a short but if has anybody experienced this painful dilemma or close to and can give me any advice i would appreciate it so much thank you so much.
Old Dec 29, 2023 | 04:49 AM
manicmechanic007's Avatar
manicmechanic007
The processor may be at fault, specifically the timing advance circuits in the processor
Try disconnecting the spout plug and starting / running it
The key on power to the coil is good right? And lights the test light?
The other side of the coil (negative side) test light blinks while cranking in run or start? Indicating a working stator in the distributor?
Check those and report back if needed
Leaving the key on will sure heat up the coil and module (normal) do not overdo it when testing and give it a rest to cool down
Old Dec 29, 2023 | 09:09 AM
thepipman's Avatar
thepipman
7th Gear
So grounding my test light on the coil. It does not light up. And it also doesn’t light when cranking… BUT. I can hear and see the spark literally coming from the coil can see the damn electrons moving from my coil to test light. But no light up from test light! Also if I go to the yellow wire under it. My test light lights up. And I was saying in my original post that it will be sparking with just ignition on. When I put my test light on the yellow wire, it stops sparking with ignition on. I know it’s getting control from the ignition module, because it flickers when cranking.and the red wire with green stripes also lights on the test light so that’s good.
Old Dec 29, 2023 | 03:26 PM
thepipman's Avatar
thepipman
7th Gear
Talking
it was the spout plug, just needed to disconnect and runs now
Old Dec 29, 2023 | 03:27 PM
thepipman's Avatar
thepipman
7th Gear
It was the spout plug thank you bro, i was swapping new stuff with old just to see if it was anything else, and the new distributor it runs alot better as well. will order a new spout read a wiring diagram and a little about it pretty cool stuff thank you so much
Old Dec 29, 2023 | 05:20 PM
88n94's Avatar
88n94
Don't count your blessings yet. Removing the spout connector takes the computer out of the equation atleast for the ignition. You may have a bad computer.
Old Dec 30, 2023 | 05:59 PM
Slumdog's Avatar
Slumdog
4wd Low
when you say spout are you referring to the plug for the tfi? Have an 89 460 with no spark. Trying to solve issue. New dizzy cap rotor tfi and coil still no spark from coil
Old Dec 30, 2023 | 06:34 PM
88n94's Avatar
88n94
Do you have any power getting UP TO THE COIL through one of the little wires that hook onto the coil when you have the ignition switch turned on?
If you do, pull the spout and check again for spark when cranking the engine.
Old Dec 30, 2023 | 09:12 PM
manicmechanic007
thepipman with that spout out set the timing to 10 degrees hot engine
Then see if it will stay running and restart with it plugged back in
Like 88n94 said
Removing that spout plug takes the processor out of the timing equation (so you can set base time)
When the processor flips out you can remove the spout and run it to verify your processor is malfunctioning
You do the same Slumdog, remove the spout plug and retry it. Yes, it is the plug by the TFI module
Old Dec 31, 2023 | 11:28 PM
thepipman's Avatar
thepipman
7th Gear
Hey question. So after doing a jumper wire to the spout harness it dies immediately. Would that indicate a short in wiring in theory ? Starts fine obviously runs choppy without it.
Old Dec 31, 2023 | 11:31 PM
thepipman's Avatar
thepipman
7th Gear
Hey question I did try using a jumper wire for the spout harness and died immediately like the new spout is plugged in. Would this indicate a faulty ecu or would there be anything to check for thank you!
Old Dec 31, 2023 | 11:48 PM
88n94's Avatar
88n94
Seems like a bad ecu(computer) but I hope someone else comments on other possibilities.
Old Dec 31, 2023 | 11:58 PM
88n94's Avatar
88n94
Did you put in a new distributor or just a distributor cap? Do you have power up to the coil through one of the small wires that hook onto the coil with the ignition switch turned on?
Old Jan 1, 2024 | 07:18 AM
manicmechanic007
I would try another processor in it or at least examine the caps in yours
My caps for instance were just barely leaking but caused a bad miss and hard trans shifting
Sure, there other hoops to jump through like intermittent or wiggle test diagnosis with a Star tester
Like the above post, power to the coil has been checked numerous times and is okay
If you've ever done any of that intermittent wiggle testing diagnosis, it is a good way to waste some time but learn a few things
If you have a new Ford module and stator in it, and the problem persists (will not start without the spout removed) replace the processor
Old Jan 3, 2024 | 09:04 AM
thepipman's Avatar
thepipman
7th Gear
benbuilder
23
Feb 17, 2014 01:55 PM
deane1935
Apr 21, 2008 02:40 PM
micah350x
Jul 9, 2007 10:47 PM
Quackhead94ranger
Jul 2, 2005 02:40 PM
mvassek
Electrical Systems/Wiring
Nov 14, 2003 06:54 PM
