starter ?
Old Nov 23, 2003 | 02:00 PM
tnmale46's Avatar
tnmale46
starter ?
truck starts fine when warm but when cold turn key clicks 2 or 3 second pause then starter kicks in starter sounds fine after it kicks in replaced selinoid didnt help any help would be greatly appericeated
Old Nov 23, 2003 | 07:33 PM
tnmale46's Avatar
tnmale46
can anyone help
Old Nov 23, 2003 | 07:37 PM
mcanik's Avatar
mcanik
What year is your truck?
Old Nov 23, 2003 | 07:39 PM
tnmale46's Avatar
tnmale46
sorry its a 94 5.8
Old Nov 23, 2003 | 07:40 PM
steve83's Avatar
steve83
What "solenoid" did you replace? The one on the starter? The thing on the fender near the battery is the starter relay. Have you checked the ground wire to make sure its terminals are clean and tight? If you start it with the headlights on, do they go out? Does it do it EVERY time, or just sometimes? If everything else is good, then the starter is the problem.
Old Nov 23, 2003 | 07:44 PM
tnmale46's Avatar
tnmale46
relay on fender is what i replaced it only does first thing in the morning when its cold
OVER 50
Electrical Systems/Wiring
Feb 22, 2014 07:04 AM
MonsterTruck\m/
1966 - 1977 Early Broncos
Jun 23, 2011 09:08 PM
MonsterTruck\m/
Jun 22, 2011 03:30 PM
TheFox302
Feb 27, 2011 08:56 AM
mrshorty
Bronco II
Nov 25, 2005 06:28 PM
