foglights
Old Apr 6, 2002 | 12:59 AM
Monochrome's Avatar
Monochrome
foglights
I am trying to reach the foglights on a 2002 ford excursion. How do I take off the license plate frame. Is it on with those "pop"bolts, can I just pry it off?
Old Apr 6, 2002 | 07:11 AM
Monsta's Avatar
Monsta
Sit. Stay.
foglights
It should be held on by two screws/bolts on the lower part of the fascia. Once they are removed it should come right off. Yours doesn't?
What happened to your foglights?
Old Apr 6, 2002 | 06:11 PM
Monochrome's Avatar
Monochrome
foglights
Mine are riveted on with the plastic bolts, there is nothing to screw. I'm putting low volatage xenon bulbs in place of the stock ones.
Old Apr 27, 2002 | 05:47 AM
AlbertoV05's Avatar
AlbertoV05
foglights
I know what you mean! My front plate bracket is attached with those plastic one-time-only "rivets" as well. I found the easiest way (and I mean easy) on my 2001 Limited was to remove the grille and reach down between the bumber and radiator. Having NEVER taken the grille off anything before, this task took a rookie like me all of 2 minutes! The entire process of removing the grill, changing the bulbs out and re-installing the grill took me 15 minutes. The only tools needed are a "normal size" flat and phillips screwdriver. Feel free to e-mail me with any questions: thetrop@netins.net
Old Apr 28, 2002 | 09:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
foglights
Yes, I stand corrected! I, too, have those dreaded little rivet thingies. I musta been thinking about my van.
I like AlbertoV05's advice! And I don't even have foglights!
Old Apr 29, 2002 | 03:03 PM
Monsta's Avatar
Monsta
Sit. Stay.
foglights
Tirewarmer
Feb 4, 2011 12:33 AM
PSKSAM2
1983 - 2012 Ranger & B-Series
68
Feb 4, 2007 12:31 PM
jdinkel
Escape & Escape Hybrid
Aug 24, 2005 11:37 PM
claytonrecord
1997 - 2003 F150
Mar 27, 2002 07:59 AM
