Alignment required when replacing front Shocks?
Old Dec 23, 2023 | 08:34 PM
excursion_7.3's Avatar
excursion_7.3
Just curious. Every vehicle I have ever owned has had front struts. I think that is not the case here right? No need for an alignment when replacing front and rear shocks then?
Thanks.
Old Dec 24, 2023 | 01:37 AM
John in OkieLand's Avatar
John in OkieLand
Struts are part of the Suspension system, and an Alignment is required.
shocks are not, replace away.
Old Dec 24, 2023 | 07:52 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Let your tires tell you.
Take a short trip on the nearest highway for about 20 minutes, to get the tire’s operating temps up. Pull off the road and quickly take temp readings on the inside/outside and center of the tires tread pattern (where the rubber meets the road, literally). If the readings on each section of tire are different you need an alignment regardless of any shock installation.
If the outsides are hotter than the center, your pressures are too low. If the outsides are cooler than the center, you have too much pressure.
This is a an old racing trick we use to optimally set up suspension and tire pressure so that the tires are as flat as possible in a turn or braking.
If you don’t have a tire pyrometer, a meat thermometer will do in a pinch, but they do not give instantaneous recovery/display of the data.
Who knows. You might need an alignment, anyway.
Old Dec 24, 2023 | 10:24 AM
excursion_7.3
So the fronts are shocks or struts?
Old Dec 24, 2023 | 11:27 AM
WE3ZS's Avatar
WE3ZS
An EX has shocks on all 4 corners, no struts.
Old Dec 25, 2023 | 09:14 AM
oharal's Avatar
oharal
Since its not a strut replacing the damper doesn't affect the alignment. I replaced mine 20k miles ago without an alignment with no adverse tire wear or change in driving characteristics. YMMV. As mentioned if you do the job and think you need an alignment due to tires wearing poorly or it drives funny, then of course you should have it aligned.
galusham
Jul 15, 2014 04:35 PM
busflyer
Jul 24, 2009 05:30 PM
crazyrwe
Jun 8, 2008 07:02 PM
gibsonj
Jun 2, 2006 12:36 PM
DS02F250
Oct 30, 2003 09:41 AM
