Swag performance intake
Old Dec 23, 2023 | 11:13 AM
rsqfxr's Avatar
rsqfxr
Anyone with any experience on replacing the intake spider with either of the the swag performance models
Old Dec 23, 2023 | 12:11 PM
RacinJasonWV's Avatar
RacinJasonWV
Maybe @ESwift has used one?
Old Dec 23, 2023 | 01:11 PM
ESwift's Avatar
ESwift
CNCFAB
I do believe I have a used one of the swag ss versions, I can go dig through my parts cabinet if needed
Old Dec 23, 2023 | 02:37 PM
rsqfxr's Avatar
rsqfxr
are they worth it? if the one you have is in your parts bin what are you running instead
Old Dec 23, 2023 | 02:47 PM
ESwift's Avatar
ESwift
CNCFAB
I bought it for a temp use for a drop in, then went to oem intake manifold, then went back to t4, if I go drop in again I would use the oem.
Guess to be straight forward, if you are looking for a performance gain, it wont give you one, and oem fits better. But, it is shiny! Lol
Old Dec 23, 2023 | 03:30 PM
rsqfxr's Avatar
rsqfxr
I was thinking by separating those pipes it might help with heat transfer and help intake air temps
Old Dec 23, 2023 | 04:27 PM
INFRNL's Avatar
INFRNL
I don't think you will gain anything. Best thing for intake temps to the actual engine is the intercooler. cold air intake doesn't even really help because that gets heated by the turbo
Old Dec 23, 2023 | 05:48 PM
Jamon Norton's Avatar
Jamon Norton
I have one on my 2000 because the factory spyder cracked when putting the turbo back on after changing boots and rebuilding turbo…. Works fine only issue I had was my boost sensor didn’t want to thread in, I ran a tap through it and all good now
speakerfritz
6.7L Power Stroke Diesel
37
Aug 23, 2023 10:39 PM
chaser1602
1997 - 2003 F150
Nov 30, 2010 07:55 AM
