More intake crud
Old Oct 18, 2022 | 04:21 PM
speakerfritz's Avatar
speakerfritz
More intake crud
https://youtu.be/gKUDlUKDqE0
Old Oct 18, 2022 | 04:22 PM
speakerfritz
Old Oct 19, 2022 | 09:18 AM
Overkill2's Avatar
Overkill2
Okay just got done watching this video. Anyone know how they put it in a new SCR section on the rocketship? I thought it was all one piece.
And thinking about this fritz, this problem was caused by the EGR injection into the intake. The problem was not caused by the CCV. But with that said, I still think it's not a bad idea to filter that crud out of the CCV reroute back into the engine with a catch can.
And thinking further, the new 20 6.7 engine uses less EGR (but more DEF) than our trucks, the 11 to 19s, do. So maybe that's why some go out way further than ours due to less sooty intake charge coming into the engine.
Just thinking out loud is all. Who knows?
Old Oct 19, 2022 | 09:25 AM
speakerfritz
these types of video's make me scream......Im going to trade in my truck and just ride an elephant
Old Oct 19, 2022 | 07:10 PM
The Bone's Avatar
The Bone
You have to be really smart to fix these trucks these days. Thank you EPA
Old Oct 19, 2022 | 09:31 PM
FishOnOne's Avatar
FishOnOne
Hopefully one day Ford will plumb post DPF exhaust for the EGR intake so there will no carbon build up in the intake track.
Old Oct 20, 2022 | 05:07 AM
Overkill2's Avatar
Overkill2
Or advances in injection technology and renewable fuel also. I remember seeing and posting a video on ducted injection that yielded zero emissions performance.
Old Oct 20, 2022 | 08:12 AM
speakerfritz
or put steam cleaning injectors in these sensitive areas....rig it up to steam cleam on occasion.
Old Oct 21, 2022 | 04:25 AM
Overkill2's Avatar
Overkill2
Or methanol injection to keep the intake cleaner and gain more power.
Old Oct 21, 2022 | 07:24 AM
speakerfritz
I wonder what the flow rate would have to be to steam clean those intake passages...and/or ideal placement of spray injectors. too much flow rate and you get too much cooling which when coupled with b5 fuels...could drop egt temps quite a bit. I wonder what the 6.7 world would look like if a spray injector was positioned in ideal crud prevention places.
I do like the idea posted earlier about moving the EGR bleed off to after the DPF....dont know if the temps would be adequate for all the emmissions magic.
Old Oct 21, 2022 | 08:41 AM
Overkill2's Avatar
Overkill2
No clue Fritz... I'm just a guy who reads a lot. If the injection side of the equation was close to being perfected, to atomize fuel more for more complete and efficient burn with less soot (incomplete combustion), then it's possible for less emissions component involvement.
I think Ford did something with the latest gen of 6.7s, MY 20 plus, by using less EGR and more DEF in their engine/exhaust emissions strategy.
Thinking about methanol injection, wouldn't that be a cool option from the factory for the guys who wanted it? Backed up by OEM research and development along with a factory warranty. Methanol injection has already been proven for performance gains since WW2 and does keep the intake/combustion chambers clean.
Ford is on top now when it comes to power but would go way over the top with methanol injection, could potentially keep the truck more emissions friendly, therefore make emissions equipment last longer. But there are those pesky bean counters.
Old Oct 21, 2022 | 08:46 AM
speakerfritz
More def and less egr….sign me up
Old Aug 10, 2023 | 12:57 PM
gary.cochran4117's Avatar
gary.cochran4117
I have the SPE CCV reroute kit installed with internal cheese grater, extended the hose to the rear of the truck, but too do not like the little bit of "smoke" coming out at idle. Have a Mishimoto HF catch can on the way and I think I will put that on the frame behind the front tire and route back up into the intake. keeping the gases in, but the oil and crap out.
Old Aug 10, 2023 | 01:32 PM
speakerfritz
this guy put into question how effective these catch can solutions are and he was right…
also, there is a thing called a seperator which is different than a catch can
Old Aug 11, 2023 | 06:14 AM
slowmans's Avatar
slowmans
I cannot speak for DEF usage on anything prior to the 20 MY but I know when I went from MA to FL back in November I had a full tank of DEF when I left and I had to fill it when I arrived in FL 3 days later. I was towing my 5er , about 13k the whole time and I used roughly the same ammount of DEF on the return trip.
