6.0 no start
Old Dec 21, 2023 | 08:58 PM
Nichols892's Avatar
Nichols892
3rd Gear
6.0 no start
6.0 2006 I replaced crank, camshaft,ipr,ipc, dummy plugs stand pipe, hfcm
Ipr volts 0.0048 while started with starting spray
new ficm also
Old Dec 21, 2023 | 09:41 PM
bismic's Avatar
bismic
So the picture is with the engine running?
0 ICP sensor volts shows a bad connection or a bad sensor. The ICP pressure (psi value) is apparently just an inferred number that the PCM has used as an "estimate".
It would help to see that same data (plus Cam/Crank Sync) when you crank and it WON'T start.
Old Dec 21, 2023 | 09:49 PM
Nichols892's Avatar
Nichols892
3rd Gear
Yes it is running with help of starting spray
Old Dec 21, 2023 | 09:54 PM
Nichols892's Avatar
Nichols892
3rd Gear
I do crank it but it won’t start
Old Dec 21, 2023 | 09:57 PM
bismic's Avatar
bismic
I understand that. What I was saying is that it would be nice to see the data in the picture again, BUT when you are cranking and it WON'T start. Also include the Cam/Crank Sync (sometimes a scan tool will call it "Sync").
That said, clearly you have an issue with getting an ICP signal from your sensor.
Baba g
Aug 31, 2024 10:37 PM
Greg1994
Mar 4, 2023 06:00 AM
avfrog
May 31, 2014 10:16 PM
