Barely starts in cold weather
Theo since you live in the area you know it got cold here last night and my 96' wouldn't fire off this morning. I didn't plug it in because it wasn't suppose to get cold. Usually it would turn over and all the white vapors of raw deisel would come boiling out. After waiting, re cycling the glow plugs a couple of times, it would fire off. This time, no white vapors. I plugged it up this afternoon and it still wouldn't fire. I think the relay went bad again. The truck ran fine yesterday but the lack of raw deisel concerns me. I'm due for new glow plug, I think. Any thoughts?
Dave,
Your list of recently replaced parts did not include the glow plug relay... is that true?
Easy enough to check, when you do your next cold start, turn the key on, then manually jump the two large terminals on the g/p relay for about thirty seconds and then (have someone) turn the key to start. Some gutsy people use big pliers, but I have SAFELY used a set of jumper cables (actually only half the "set") When it fires up, you can pull off the jumper cable.
All the cable is doing is letting the current flow through the cable to the plugs...same thing the relay is suppose to do!
Help that helps!
God Bless,
TC
Help that helps!
God Bless,
TC
The pump and reservoir is mounted on the top front of the engine. There is usually a plastic cover over it. Use a 1/4 inch ratchet or breaker bar and remove the plug on top. You should be able to see oil in the tank. If its low, fill with what ever you use in the crankcase, install the plug, and try to start.
elwardo13
10-19-2005 09:39 PM
