Time for new Engine mounts
Old Dec 21, 2023 | 05:05 AM
12Stratford's Avatar
12Stratford
Seller of my 66 F100 included new mounts for the Ford 400. 2 months since we bought the truck I decided to dig into it. Engine hoist made this job a piece of cake even though space under there is tight. The old mounts were trashed.
New
Old
Old Dec 21, 2023 | 05:15 AM
charlie g's Avatar
charlie g
FTE Community Team
i would say TG it had that safety rivet, other wise the throttle tends to go wide open, hear you on using the engine lift,
Old Dec 21, 2023 | 05:32 AM
12Stratford
Yes
That rivet was the only thing holding it together. Initially I thought I would never be able to rest the top most of the 3 bolts to the block, it was hidden into the rubber cause it had semi collapsed. Once I hoisted it a bit the bolt head was clear. That was a relief. I work in slow motion. Lots of thinking, rarely charge ahead. I used thick nylon marine line wrapped under the crank Pully so I could rock the engine while supported by the hoist.
dedward
15
Apr 24, 2023 12:15 PM
keisha9
May 20, 2016 08:49 AM
willthesaint
Apr 4, 2016 07:42 PM
ROBBINthaHOOD
Sep 19, 2012 03:42 AM
