new carburetor
Old Dec 20, 2023 | 04:50 AM
Ericfromfrance's Avatar
Ericfromfrance
new carburetor
i'm thinking about a new carb for my 460ci 1977 f250 2WD.
do you have any recommendation on a particular model ? i'm looking too for a good dealer ?
thanks
Old Dec 20, 2023 | 06:35 AM
jflem's Avatar
jflem
I have a 77 F150 with a 460 and I installed a 600cfm Holley Street Warrior and so far I am pleased with it.
Old Dec 20, 2023 | 07:22 AM
Ericfromfrance
where did you buy it ?
do you have an electric choke ?
what do you think about the classic 750cfm holley ?
Old Dec 20, 2023 | 07:38 AM
jflem's Avatar
jflem
Yes it has electric choke. I purchased it from Holley as a rebuilt one. One they took back for warranty and fixed. So really it was just like new.
Old Dec 20, 2023 | 08:23 AM
Ericfromfrance
did you need to do some adjustment after you mount it ?
Old Dec 20, 2023 | 08:29 AM
jflem's Avatar
jflem
Best I recall it was adjusted perfectly when i received it. I replaced a 750 cfm which is not needed for my engine. I only have a mild cam and high-rise intake and headers.
Old Dec 20, 2023 | 08:46 AM
Ericfromfrance
what about your miles per gallon, is it better?
Old Dec 20, 2023 | 08:56 AM
jflem's Avatar
jflem
A slight improvement over the 750 that was on it. I did not get to drive it much after the swap since I took it to the body shop and it has been there for a year now. I hope to get it back real soon. I was getting a little over 8mpg around town. I'll work on that when I get it back. I have a 3.25 rear axle.
Old Dec 20, 2023 | 09:22 AM
uzikaduzi's Avatar
uzikaduzi
i would want more cfm than less. a 750 or 850 would be my choice and a double pumper design like the brawler should give better throttle response.
i've always heard the general rule is to double the cubes in cfm as a good target to maximize hp's... dropping below that target robs hp starting at the higher rpms so taking that target literally for a 460 in a truck is likely a waste because you likely don't care about what it makes at 6500 rpm, but obviously putting a smaller carb on only improves mpg by limiting you from putting more air and fuel through the motor.
i run a 600 street warrior on my 302 in my f100 and it seems perfect... i swapped a 750 brawler in place of the 600 street warrior the PO had in my 390 f250 and it really woke it up. the only reason i get worse mpg's is because i can't keep my foot out of it.
Old Dec 20, 2023 | 09:52 AM
440 sixpack's Avatar
440 sixpack
A 600-650 would be best, a 750 is overkill but it's what I'd run. your best option would be a 4160 electric choke with single feed. double pumpers are not for pickups and especially not for an automatic without a stall.
It will come factory adjusted you'll just have to set idle mix and speed. after running it you may need to adjust the choke or jet it a little if you want optimum performance.
Holley is the king for a reason, they just work. and they're simple to work on and all the parts are at any local auto parts store.
Old Dec 21, 2023 | 03:04 AM
Ericfromfrance
this one ?
https://www.npdlink.com/product/carb...e/218272/51500
Old Dec 21, 2023 | 05:57 AM
jflem's Avatar
jflem
Yes that is the one I installed. Mine was not polished best I recall.
Old Dec 21, 2023 | 10:13 AM
440 sixpack
That would work, but personally I'm not a fan of any of the warrior series.
I have 4 of these on everything from a 428 to a 460. they work perfectly.
Holley 0-80459SA 750 CFM Classic Holley Carburetor
One thing to remember is CFM has nothing to do with fuel economy, within reason of course. how you drive and your jets determine how much fuel is metered in. the only disadvantage to sight excess CFM is throttle response and there is no noticeable problems with a 460 or anything like it. there is no advantage either until you reach an RPM you're not going to see.
The 600 will work fine, so will the 750. it's just personal preference. spend a few minutes jetting them in and you'll be happy.
Old Dec 21, 2023 | 10:23 AM
Ericfromfrance
hmm classic vs warrior, difficult choice
Old Dec 21, 2023 | 10:39 AM
440 sixpack
They're essentially the same carb. the warrior series just does some dumb things just to be different for marketing purposes, like the phony screws on the float adjustment that look like they belong on a dishwasher. why.
