Truck clutch equalizer
Old Dec 18, 2023 | 03:43 PM
mikei16's Avatar
mikei16
I have a 1951 F3 I have the clutch shaft for it but it looks like it was re-clocked does anyone have one that could tell the position of the frame side and the clutch shaft side?
Thanks
Old Dec 18, 2023 | 04:27 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Which transmission?
  • Heavy Duty 3 Speed (Center Shift)
  • Heavy Duty 3 Speed (Remote Shift)
  • 4 Speed Crash Box?
  • Something else?
Old Dec 18, 2023 | 04:45 PM
cruisetopdown's Avatar
cruisetopdown
This is the best pic I have, not sure it helps.
w
Old Dec 18, 2023 | 05:38 PM
mikei16's Avatar
mikei16
T5 GM out of a 1995 S10
Originally Posted by bmoran4
Which transmission?
  • Something else?
Old Dec 18, 2023 | 07:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You can see on Cruise's picture, the trans end is at about 45° (he also has a T5).
This is the only picture I have of the other end, should give you an idea of orientation. The frame end is angled to the rear, not quite 45°..
Old Dec 18, 2023 | 07:23 PM
bobj49f2's Avatar
bobj49f2
Will this work?
Old Dec 18, 2023 | 07:28 PM
mikei16's Avatar
mikei16
Ok thanks, with that end in that position do you have any idea where the clutch fork would be? Would it be back all the way towards the transmission or be somewhere between the transmission and the fingers of the pressure plate. This would give me an idea of the orientation of the end that goes on the clutch fork shaft.
Thanks
Old Dec 18, 2023 | 07:40 PM
bmoran4's Avatar
bmoran4
Pictures of Ford Part 01A-7510 show the mating shaft and the fork mounting pin:
https://www.google.com/search?q=ford+%2201A-7510%22
The fork is Ford Part 48-7515 and the pin is 352581-S7
https://www.google.com/search?q=ford+%2248-7515%22
These parts were used across varios Ford cars, trucks, and tractors.
Old Dec 18, 2023 | 08:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Thanks
That particular truck is missing the return spring, so it is probably not as far back as it could go.
Old Dec 19, 2023 | 04:23 AM
fish pond's Avatar
fish pond
you say clocked are you refering to rotational ore n tation? please forgive my spelling.
I haad issue with my 51 M3 going back together after getting fly wheel ground,new clutch assm., also the shaft an bushings goin thru bell housing, and using the trans.from a F5(T98)
The issue was the clutch adjuster(little u shaped gizmo with a 7/16-20 tapped hole in it )was not long enough to adjust proper like, my cure was machining a longer gizmo for thee adjuster.
I blamed my issues with(perhaps?) the new shaft for throw fork was not perfect with the "clocking" of the shaft and throw out fork,plus the grinding of flywheel.
What is your issue?
Greg
Old Dec 19, 2023 | 05:00 PM
mikei16's Avatar
mikei16
Hi guys, thanks for all your help! I ended up re-clocking it (position) 3 times and shorting the adjusting rod off of pedal.
Thanks again
Mike
fire.ice07
15
Dec 18, 2023 06:56 PM
Ryan Sigman
Mar 23, 2013 07:55 PM
fordf350crazy
Aug 3, 2009 07:41 PM
