Picked up a 2004 E350 w/ 6.0. Hard start cold, starts fine plugged in.
Glow plug codes #1,3,5,7.
Could this just be one side unplugged at the controller?
Most of my diesels have had a relay, the controller is new to me. I assume it's in the same spot as the pickup, I'm not sure how much I'll have to disassemble to get to it.
Those controllers have a very low failure rate, like said above check the plugs and look inside the connectors I have seen one burned before and Ford does offer a repair kit for the harness.
