2016 2.7 coolant issue
Old Dec 17, 2023 | 02:04 PM
Jreitter's Avatar
Jreitter
8th Gear
I’m losing coolant out of this thing and I have no idea where it’s going. The oil isn’t milky looking and I’m not seeing any leaks around the engine compartment. Is it possible it’s going out the exhaust somehow? Has anyone had any issues like this? Truck has 119k miles
Old Dec 17, 2023 | 02:08 PM
charlie g's Avatar
charlie g
FTE Community Team
2016 with high miles, check for a leaking heater core, if it had engine issues you would have a sicking sweet smell from the exhaust
Old Dec 17, 2023 | 05:28 PM
JKBrad's Avatar
JKBrad
Check the coolant lines for the turbos.
Old Dec 18, 2023 | 01:44 AM
charlie g's Avatar
charlie g
FTE Community Team
possible , yet he would smell it under the hood, remember the 2013 escape with the 1.6 liter turbo hoses issue?
Old Dec 18, 2023 | 10:19 AM
GlueGuy's Avatar
GlueGuy
Yeah. If there is a leak, it should show up somewhere. OTOH, if he doesn't have a misfire, then it may be going somewhere else. How bad is the leak? Can you do a pressure test on the cooling system?
Old Dec 18, 2023 | 11:03 AM
charlie g's Avatar
charlie g
FTE Community Team
mechanic nightmare is finding leaking heater cores. .if really bad they tend to flim up the windshield , the coolant mixes with the a/c drainage hitting the ground, i'd be doing a black light die test of the cooling system .
Old Dec 29, 2023 | 02:15 PM
Jreitter's Avatar
Jreitter
8th Gear
It’s definitely not the heater core. I’m smelling it out the exhaust on cold starts. Oil looks fine but wondering if this gasket is cracked and leaking out the exhaust ports?
Old Dec 29, 2023 | 08:32 PM
JKBrad's Avatar
JKBrad
2.7 doesn’t have manifolds, the exhaust goes directly from the head to the turbo.
socal_pzy
Nov 11, 2021 10:44 AM
Da_Lariat_Chariot
Mar 28, 2015 02:22 PM
dalestotlar
Jul 4, 2013 09:38 AM
Flytyer
1983 - 2012 Ranger & B-Series
May 17, 2011 11:19 AM
zgiannijonesz
1997 - 2003 F150
Oct 30, 2007 08:43 PM
