Sponsored by: Auxito
Vacuum leak probably
Old Dec 14, 2023 | 08:05 AM
Rollingscrapmetal's Avatar
Rollingscrapmetal
I was planning on driving home for the holidays but I swapped the radiator and air filter and now lose all power at 55 with codes p0308 p0307 p0174 which tells me vacuum leak
I pulled the whole piece between the throttle and air filter out and fixed a leak on one of the big plastic lines going into it but I'm not seeing anything wrong otherwise except the air filter doesn't quite fit right and I'll be getting a new one today but any other ideas because I've cleared the codes repeatedly and they keep coming back
Old Dec 14, 2023 | 09:28 AM
BareBonesXL's Avatar
BareBonesXL
What is it that you're working on?
The air filter needs to fit correctly. The whole system is designed to give proper flow around the MAF sensor. Turbulence can cause MAF sesnsor problems. Put the old filter back in and see if the problems go away. Or unplug the sensor.
Old Dec 14, 2023 | 05:40 PM
Rollingscrapmetal
2001 f150 5.4 4r100 4wd
Old Jul 1, 2025 | 10:20 PM
Rollingscrapmetal
Cracked a spark plug putting it in
pnp522
1983 - 2012 Ranger & B-Series
Sep 15, 2012 04:54 PM
alstieg
Jun 7, 2007 09:54 AM
TX F-150 4x4
May 29, 2007 10:47 PM
DBray6
Feb 5, 2007 10:16 AM
mainernexile
Modular V8 (4.6L, 5.4L)
Jul 23, 2004 10:34 AM
