Vacuum Leak?
Old Jun 7, 2007 | 09:09 AM
alstieg's Avatar
alstieg
Vacuum Leak?
I got a 5.8 in a '95 ('96 motor) 4x4. the cel goes off and on. ran the codes and the main code was 552 Air management 1 circuit failure.
I figure I have a air leak so I did a visual check on all the small lines and didn't find anything. its almost impossible to find slits in the plastic hoses. truck idles ok but doesn't seem to get as good mpg.
are there little solenoids or switchs that could be bad?
Old Jun 7, 2007 | 09:54 AM
92F150Flare's Avatar
92F150Flare
Those plastic vacuum lines are hard to check. I found that I had to feel them, right up close to their connectors and if they were bad they usually broke off in my fingers. Not easy to find
Good Luck
