Sponsored by: Real Truck
Quick Compatibility question, please
Old Dec 13, 2023 | 06:17 PM
at1094's Avatar
at1094
3rd Gear
Quick question, please. I have an 03 f250 lariat 2wd long bed. I have the opportunity to pick up a leveling kit but with stock shocks and springs from a fellow with a 2010 F250 4wd; he upgraded to a huge lift. Will this bolt right up to my truck without modification? Thank you so much in advance to any info I y’all have to give!
Old Dec 14, 2023 | 09:51 AM
BlackBeest's Avatar
BlackBeest
When I was researching lifting the front of the 6.2 gasser 2wd, the 4wd springs were not compatible. I don't think it's anything insurmountable, tho. Something to do with the tightness of the coiled end that attached to the upper and lower perches, they're curled at a different angle. Victor wrench and a pipe should "fix" it, but also be aware if his truck was a diesel, the spring rates will be much stiffer to account for the heavier engine, if yours is gas.
Old Dec 14, 2023 | 11:23 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I doubt it's a direct fit, but it SHOULD be possible if you're willing to put in some work.
Definitely easier to just get the right kit for your truck.
fusefinder
Jun 23, 2018 02:25 PM
billpinsc
Dec 28, 2016 10:18 PM
countryboy96
Jun 20, 2012 08:15 PM
06F150Guy
2004 - 2008 F150
May 15, 2009 08:36 AM
vajeeptj
May 19, 2006 02:16 PM
