Distributor cap/rotor question...
Old Dec 29, 2018 | 12:32 PM
ScottyC50's Avatar
ScottyC50
Good afternoon!
i was looking to replace my cap and rotor with an msd model. However, when .I looked, there is one available with a spacer, and one without. When looking at the truck, I cant tell, but it looks like a spacer is there. What do you all think?
Also, if I change out the wires, what might you recommend? Accel or Motorcraft, or maybe something else?
Thansk for your input. I'm still a newbie an mechanics, but loving getting to know my truck..
Pic of the distributor cap
Pic 2 of distributor cap
Old Dec 29, 2018 | 12:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Male end dizzy cap and the plastic adapter it clips onto introduced in 1977.
Old Dec 31, 2018 | 04:15 AM
Ozzie H.'s Avatar
Ozzie H.
I used the MSD wires. They worked well.
Old Dec 31, 2018 | 11:41 AM
meangreen92's Avatar
meangreen92
You're all set. If that's your dizzy in the picture, with the blue upper cap, then you already have the spacer which will accept a new Duraspark II cap of your choosing.
You want the cap which works with the spacer, but you shouldn't need to buy their spacer. If you had a points distributor, you would get the spacer and then be able to run MSD or Duraspark caps in place of the smaller points cap.
Are MSD caps and rotors good to use on a daily driver?
68murc
Nov 14, 2015 08:09 PM
bhesse
Jun 24, 2014 02:54 PM
Tom Dowdell
Jul 30, 2009 11:14 PM
bigtymer77
Nov 4, 2008 05:15 AM
GregCS
Jul 5, 2000 09:52 PM
