Sponsored by: Real Truck
Rear gear change/speedometer correction
Old Dec 12, 2023 | 03:16 PM
bigcountry1009's Avatar
bigcountry1009
2003 F-250. After a rear gear change, what is required, if anything, to correct the speedometer? I’m going to a salvage yard rearend and the gear will be different. The truck had a 4.56 gear installed in it.
Old Dec 12, 2023 | 03:20 PM
redford's Avatar
redford
FTE Leadership Emeritus
The speedometer signal is taken off of the ring gear on these trucks. The ring gear spins one revolution per one tire revolution, regardless of the ring gear size, so no adjustment is needed for a new gear set.
Old Dec 12, 2023 | 03:39 PM
Ted722's Avatar
Ted722
Went from a 3.73 to 4.56 last year on my ‘03 F250. No change in speedometer reading (checked with GPS too). RPM on the other hand! 🙂
Shadowrider123
19
Jan 20, 2015 05:56 PM
Zachthemoo2
Oct 2, 2014 04:42 PM
kevinfelix
22
Aug 1, 2011 03:06 PM
yellow72f100
Nov 2, 2005 06:52 PM
Ray D
16
Feb 10, 2001 08:49 PM
