Rear Differential Replacement
Old Dec 11, 2023 | 01:40 PM
Billy J Mitchell's Avatar
Billy J Mitchell
1st Gear
Hi... does anyone happen to know what the diameter of the pinion shaft and the diameter of the ring gear of a stock 1948 F1. I'm looking to replace the original ring and pinion to a higher ratio. Any suggestion on where I can find one?
Thank you,
Billy
Old Dec 11, 2023 | 04:34 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Here is documentation on the Ford stock offerings with Ford part numbers you can use with specialty vendors:
Old Dec 11, 2023 | 05:52 PM
3twinridges's Avatar
3twinridges
Hi Billy
Randy’s ring and pinion makes a good replacement, I used their kits to move our F1 to a 3.54 and am very happy with it.
JB
Old Dec 13, 2023 | 06:04 PM
38 coupe's Avatar
38 coupe
The 48 through early 50 F-1s use a Dana 41 rear axle. Re-gearing an early F-1 has gotten so popular that a reproduction 3.54 gear set has been made. Part number 8C-4209, available from several vendors (example one here). Disclaimer, I don't remember if there is a carrier break in the Dana 41 that you need to be aware of before changing gears.
frankcowan
13
Jun 17, 2014 09:13 PM
dmeyer 351 4x4 rebel
28
Dec 26, 2010 08:37 AM
Woodsman_30350
Sep 23, 2008 12:52 PM
76f250highboys
Jun 22, 2008 10:58 AM
lbianc1
1978 - 1996 Big Bronco
May 5, 2004 10:44 AM
