ring and pinion
Old Dec 21, 2010 | 10:45 AM
dmeyer 351 4x4 rebel's Avatar
ring and pinion
if i change the ring and pinion in the rear do i have to change it in the front
thanks for any help
Old Dec 21, 2010 | 10:51 AM
Conanski's Avatar
Conanski
If you're going to a different gear ratio yes.
Old Dec 21, 2010 | 10:53 AM
even if i runing the same ratios that i already have
Old Dec 21, 2010 | 11:10 AM
rla2005's Avatar
rla2005
I think Paul answered that question in Post #3. If the gear ratio remains the same, then no you do not need to replace the ring and pinion in the front. Unless of course the front has some other issue as well.
Why are you replacing the rear gears?
Old Dec 21, 2010 | 12:26 PM
the backs are all chewed up the teeth are bad
Old Dec 21, 2010 | 12:30 PM
rla2005's Avatar
rla2005
Sounds bad. You should inspect the front to see if someone "chewed" that up as well. Most likely okay, but better to find out now.
Old Dec 22, 2010 | 01:06 PM
ya whers the best place to buy new r n p
Old Dec 22, 2010 | 02:25 PM
rla2005's Avatar
rla2005
I have purchased parts from here before: Randy's Ring & Pinion. The Differential Experts. Auto Parts & Services. Great service, products and support.
Old Dec 22, 2010 | 02:53 PM
aguitarestv's Avatar
aguitarestv
you can get them from broncograveyard.com as well, or try to find a set on ebay for cheaper, found sets of yukons for cheap money a wile back, but didnt pull the trigger...
Old Dec 22, 2010 | 05:18 PM
Encho's Avatar
Encho
The Southernmost Mod
If you change the RATIO, you should match front and rear, i.e: you had 3.55 (that would be on both axles), if you change the rear to a 4.10 ratio, the front should be matched to that 4.10 ratio also.
Old Dec 22, 2010 | 11:20 PM
ok ya so you are saying that i have the 3.55 in my 92 f150 4x4
Old Dec 23, 2010 | 02:39 AM
hav24wheel's Avatar
hav24wheel
Most likely 3.55s. Aren't yoou planning a big lift and stuff too?
If so, now is the perfect time to swap to lower gears. Pick a tire size, than match your gears to that.
Old Dec 23, 2010 | 03:00 AM
Skip1970's Avatar
Skip1970
dont be afraid of a used ring and pinion from a junkyard either, they will be cheap.
Old Dec 23, 2010 | 07:24 AM
zxwut?'s Avatar
zxwut?
Oh yeah! and cheaper is always better, right?
