Bracket ID
Old Dec 5, 2023 | 10:52 PM
CJMOStang's Avatar
CJMOStang
Bracket ID
While wiring in the dash today I cut my hand on this bracket directly under the steering column. Could someone help me ID this?
Old Dec 5, 2023 | 11:09 PM
52 Merc's Avatar
52 Merc
It holds the turn signal flasher. It will slip into the spring loaded fingers either from the bottom, or from the sides, depending on which way you want it to sit, and the wires to protrude. It's actually a nifty little design.
Old Dec 7, 2023 | 08:32 PM
ajsunnyB's Avatar
ajsunnyB
Burbank Washington you are so right! I don’t know why they are so sharp. Like a stake knife. I moved my flasher bracket, but I have the heavy flasher it’s longer. And now twelve volt.AJ
Old Dec 7, 2023 | 11:49 PM
CJMOStang's Avatar
CJMOStang
Thank you - it’s clear now - I kept thinking under dash dome light
Pdesgens
Apr 1, 2022 05:11 PM
barryjdi
Oct 28, 2014 09:48 PM
Outlaw56
Jul 22, 2013 09:34 PM
rolandm
Jul 13, 2008 08:04 PM
