Alright so you may have read about my nightmare I had with my pcm, well in the process of ****ing around I broke the fuel regulator return cap. So I ordered a new one. No spring with it sadly. So I'm wondering is it alright to throw a bb in here like I've read about and heard about or is that a crock? Thanks again guys.
Yea there junk. Trucks been down for to long already. I'm throwing the pot metal on there for now. Will look into ordering this one. This was part came in 2 days nobody else could.
Another option before you go full FRx: https://dieselorings.com/products/7-033-fpr-housing-billet-aluminum-w-pressure-shim-springs Might be cheaper/faster from Riff Raff due to your location: https://www.riffraffdiesel.com/fpr-housing-billet-aluminum-w-pressure-shim-springs/
Yea these are definitely an option, i wished i lived in the states so i could get parts faster.
That first site is reliable to order from? I shall definitely be ordering that when u get the chance. I like how it comes with three different springs that's sick. I see the riff raff one does as well. Maybe I'll give that one a try. I'll see what shipping that to Canada is like.
Sweet well hopefully I can find a compression sleeve from a parts store or can make shift one up. Any ideas? I need this truck on the road yesterday...
5/16” ID for the OD on the return line. Not sure of the OD on the compression sleeve.
If that's the case a 1/4 fuel line cut into a little look alike should work no? I might try it if I can't find a compression sleeve today. Truck is like a half hour away in a sketchy city so I just want to get it home.
